#16 |
Sounds like a short with that wire, I would follow it and see where it leads, or your interlock switch failed (black and red wire), or antitheft system failed or engaged it self (black and green wire). I am looking at an 86 RX7 diagram as well if it is a different year please post and I will get you the correct wire colors.
#17 |
the car is an 86 i have bypassed the interlock switch and i have no anti theft system it is bypassed also
#18 |
Did you check the circuit breaker relay?
#19 |
theyy were fine didnt need reset
#20 |
Whats your volts when the switch is in the run position?
#21 |
0 switch only has volts on the off position
#22 |
I have Ultra power in me.
Rep Power: 14 ![]() |
where are you taking the reading at?
#23 |
im am testin volts on the w/r wire on the back of the ignition switch its got 12v in the off position but is says .50v on acc and 0 on start
#24 |
just for giggles meter at the battery and see what happens. If the volts drop way off you may have a short.
#25 |
Rep Power: 20 ![]() |
I still assert that you have a bad connection at either the battery or a ground. Check your voltage there when you try to start and at the main relay in the engine bay. I believe it's labeled XM-1 in the wiring diagram.
#26 |
I thought I have metered my car at the switch before and have similar results but the car started. post a pic of where you are metering if you can.
#27 |
The only thing it can be at this point is crossed wire, failed relay(s), or a bad connection(s), or short(s).
#28 |
ok so ive been tracing wires checking connections and grounds all are clean, i opend up the ignition switch that was told was working condition and it was rusted to hell so i orderd a brand new switch from mazda, how is it possible that all 4 ignition switches are bad and showing the same volts in the acc position and run position .
#29 |
Rep Power: 21 ![]() |
perhaps a design fault?
#30 |
you could jump wires and see if that works
Bookmarks |
Thread Tools | |
Display Modes | |
