Banned
Fan Relays
Anyone know which one of the four fan relays would cause the fans to stay running after the ignition is switched off? thanks
Do they run untill you do something to disconnect them OR do they run for about 10 minutes and shut off .The ten minute thing is built in with later models .
Banned
hey David - I haven't timed it, but they never stayed running with the ignition switch on before
WNC Tour Guide
To turn the fans on, it's a combination of at least 2 relays... I can look up the diagrams again if you need it because I can't remember the setup off the top of my head...
what have you changed recently that could contribute to the new behavior?
not to hijack.
But my FD - suddenly fan were not shutting off. I had to pull the fuse to get them to stop. Now fans won't run once temp is reached. But I can turn the car off, then on and the fan come to life. I am assuming it the fan relays. I plan on just replacing all of them. YZF - rx7.com may be able to help you and order the correct relay at the same time.
This is going to tear |
#6 | |
Banned
I wouldn't mind looking at the diagrams if you can post, thanks |
#7 | |
Viable Fossil
----> http://www.fd3s.net/fan_circuit.html
Jim VR R1 FD |
Banned
Yes it does, thanks
#9 |
Rotary Non-conformist
There is also a recall control module added to the fd's located next to the ecu. It's a little black box that allows the fans to run if the car is turned off and the temp is at a certain range. I have had to replace said box to get this system to work again, before I removed the factory fans and relays from the car when I built a custom cooling system.
#10 |
Banned
I think I've seen this black box, what happens if you just disconnect it?
#11 |
If you remove the box and the adapter wireing harness it will go back to the way it came from the factory . It is just an unplug and replug the harness
#12 |
Banned
Fans run for 10 minutes after the ignition is off, right?
#13 |
Something like that .
I have had that system removed from my car for years and I never put a clock on it when I replaced the control box. sorry |
#14 |
Banned
My biggest concern is draining the battery running the fans that long...
#15 |
If the battery is of good condition 10 min or so fans running to remove heat should not be a problem. A lot of new cars now days have this kind of system and if I remember when the control box turns the fans off the system turns off (not sure on that but i think that's how it works.
