Old 04-12-2008, 01:15 PM   #3
J-Rat
J-Rat is on a distinguished road
Originally Posted by Rotaryrocket FC View Post
No turbo guru's here?
What can I do for you?
*Engine management systems
I have tuned Megasquirt, Microtech, PFC, Haltech, and SAFCs (if you want to call that tuning). In my humble opinion, Haltech is the best bang for the buck. I caution against the E6X because of the different reluctor used in that model. Get the E8 or E11 if you can afford it, or an E6k which is what I use.
*Ignition, Oil, and Fuel upgrade tips
Asking about ignition is going to get you a hundred different answers. I was running a single Jacobs Pro Pak on JUST the leading stock coils. Made 497 wheel. I also did this on a single Walbro pump something a lot of "gurus" here will tell you cant be done (they might also tell you I spray alchohol, dont listen to them.. Lies I tell ya!!!) My ignition is now a Jacobs FC1000. Dont need the 2000 because the Haltech already has a rev limiter. I also run 890 primaries and 1680 Ford Secondaries.
I could go on forever about timing, but I run crazy advances. My engine builder saw the map I was using once and about passed out. Probably shouldnt listen to me on timing...
*Tuning responsabilities
Not sure what you mean here.....
*A/R ratio's fitting to my needs
Yet another topic of debate. I run mid to low 11s at full boost with a little lean out in the spool up area, but I also run alot of timing. Some people will disagree, some will agree. At the end of the day, its all up to what you. I also run an MSD Knock Box that lets me know when knock is starting. Pretty handy tool if you ask me!
Let me know what other questions you have.
Rat
1988 10th Anniversary
554 RWHP, 395 RW Torque
10.7 @ 126!
owner:
www.azrx7.com
Engine built by ARIZONA ROTARY ROCKETS
www.azrotaryrockets.com
J-Rat is offline   Reply With Quote
