Old 10-11-2011, 07:37 PM   #11
Judge Ito
Porting Master
Judge Ito is on a distinguished road
Originally Posted by Mazdabater View Post
Wait this engine is in a first gen? If so that makes me even more doubtful it's got 280hp. Also I don't know of any cars that have a problem with a clutch that only affects certain gears.
I'm not sure what your problem is, from the beggining your insinuating that a stock ecu cannot achieve these goals, then you go on and on. For your information, I have dynoed over 327rwhp with a stock ecu over 10 years ago. and ran 11.7 with that same stock ecu in a series 4 turbo II..
not only did I post a dyno sheet but also posted a dyno video pull. i'm not here to brag but to show the potential involved with a simple set-up like this. I could even tell you on a 10lbs of boost pull my kid's car made 291rwhp. I didnt post 291rwhp because the engine went lean and that is not a realistic goal/tune..
the car made back to back 280rwhp @ 9psi of boost with the proper A/F ratio, and that jack is the facts believe it or not..
here i'll post some pics her clutch with tons of heat spots from slippage.. I hope you know how to read a slipping clutch.. so sit back relax and enjoy the progress on this simple but effective build..
Judge Ito is offline
