Old 09-28-2011, 11:12 PM   #1
TitaniumTT's from scratch Track Trailer
Soooooo I figure I'll post this up as a few members here have helped with the design of it, and they've been asking for progress pics. I do need to get some more pics taken as the thing is rolling, although it's not completely finished yet.... hopefully in the next few weeks I'll have the time.... Any who, this will probably take a few days to get the whole thread up.
All of the tubing used is 2"x2"x.125" 6061 AL, the round tube is 2"x.125" 6061. The gussets I believe are 5052... not entirely sure actually
This is the basic design layout. From the back of the round tube to the front of the square tube is 53", the outside to outside dimension is 53" as well. I based these dimensions on the tires I was planning on buying, and some that are larger for when.... or IFF I ever get the FD done and start taking that to the track as well.
Without a perfectly level and true surface to weld on, I had to improvise. The though was, if I start making the side completely square, and tack them together, then when everything comes together, it will also be perfectly square. It actually worked out. I honestly cannot measure the trailer out of square. It is literally perfect... I was shocked.
So here is the first side. The square tubing on top keeps them on the same plane.
That would be the leg of my engine hoist It was the only piece that I had around that was long enough to make the spread. Made sure everything was square before welding it all together
There's the tongue. I guessed at how long it would be, and then added a little bit because it's always easier to take metal away than add it
Welded everything in place and kept checking for square at every step of the way.
All the jigs removed and rechecked.... weeeeee!!!! still square!
