Old 08-30-2011, 08:41 AM   #19
Originally Posted by Fidelity101 View Post
How close are the rx8 brackets to FC brackets? or did you unbolt the Rx8 seats and throw them on the FC rails?
PS: I like it!
If you look at the pics you can see the amount of adapting necessary. The FC brackets were removed from the sliders and bolted to the floor. The Rx8 rails were removed, all brackets and locating studs were removed, and the rails were reinstalled to the seats with a flat surface on the bottom (sliders intact). The Rx8 rails are almost two inches wider than the fc rails. In the pictures you can see some square stock that was used to "build up" the FC rails upward and outward to get the correct height. The rx8 seats were then placed on the new "brackets", lined up, and the sliders were then welded to them. The driver's side is relatively basic and consists of two rails as described, but the passenger seat is much more tricky. The seat height is determined by the trans tunnel and mounts, which is why the brackets had to be "built up" to match. It also needed slightly more creative welding to bolt to the factory locations. In the picture you can see that the FC section on the passenger inner bracket was welded to the front of the rail to provide the correct location. The entire rail basically sits on the trans tunnel. It makes more sense in person. Also, the passenger seat is sliding only, but the driver seat is power adjustable and the seat bottom can be lowered quite far. A 6'2" person has sat in both seats with his hair touching the top, but his hair is/was rather pointy. I'm 5'8" and have plenty of room. When a tall person sits in the car I just tell them to put the top down. Infinite headroom.
