Old 03-17-2011, 12:44 PM   #46
To_Slow
Another set of 13b REW irons received full treatment from Chips Moto,,
Uploaded with ImageShack.us
www.chipsmotorsports.com
Your place for all rotory engine modifications ( Street and Race )
My link
Old 03-27-2011, 01:47 PM   #47
Judge Ito
Porting Master
Judge Ito is on a distinguished road
question I have. upon rebuilds with the thermal barrier coating. have you seen a drop in water temperature?
Judge Ito is offline   Reply With Quote
Old 03-28-2011, 09:20 AM   #48
To_Slow
Heat treating the plates with nitrating process will not help with cooling, its the same process the factory uses on new plates, minus the coil induction heating on the center of the plates,
Its the same thermal result you will get with any Mazda new plates.
Thanks
My link
Old 03-29-2011, 06:27 AM   #49
Judge Ito
Porting Master
Thanks
looks near perfection. have you seen how long this treatment stays on the plates? any tear downs with info?
Old 03-29-2011, 06:56 AM   #50
To_Slow
I did tore down a engine for a customer at his place do to a stuck/cracked side seal, at about 42k miles on the build,
Took pics with my phone the condition of the plates, there were only visual signs of the travel of the seals but no measurable step wear on the plates.
I would safely assume that these last close to or the same as new OEM plates...
Will have more back to back info with data etc in the future...
Thanks
My link
Old 06-06-2011, 10:29 AM   #51
Mateepay
Mateepay is on a distinguished road
im curious to know if your service is reserved for 13b engines as i have a 12a i would be interested in having the service done to. i would be interested in an estimate(480)?
Mateepay is offline   Reply With Quote
Old 06-10-2011, 06:52 PM   #52
JDriftM
Dedicated Rotorhead
JDriftM is on a distinguished road
I have a full set of S4 Turbo Irons and the problem is that they have burn marks on all but one face (which is on the rear side of the center iron), can you re-nitride and then lap these and make them usable again? Or am I looking at a lost cause?
-Tim
DGRR 2013.
JDriftM is offline   Reply With Quote
Old 06-10-2011, 08:00 PM   #53
To_Slow
-Tim
For sure they can be done.
Do email me some pics chipsmotorsports@gmail.com before you decide to send them in.
Thanks
My link
Old 06-14-2011, 08:17 PM   #54
JDriftM
Dedicated Rotorhead
I'm still a little ways away. That's awesome to know they're still good.
I'll definitely be in touch.
Thanks!
DGRR 2013.
Old 06-30-2011, 12:34 PM   #55
To_Slow
Plates before and after for a forum member ...
Pricing and info.... http://www.chipsmotorsports.com/serv...d-re-nitriding
My link
Old 07-05-2011, 12:57 PM   #56
To_Slow
Here is another set of irons done for a club member.
T2 housings
For service and info http://www.chipsmotorsports.com/serv...d-re-nitriding
My link
Old 07-05-2011, 10:50 PM   #57
NoDOHC
NoDOHC's Avatar
Why does the center plate look like it is from an NA engine? I can't see the Intake port edge to look for a tapped hole above the ports, but the oil fill is distinctly from an NA engine.
Old 07-06-2011, 08:18 AM   #58
infernosg
IT'S ALIVE!
infernosg's Avatar
That's because it's a N/A filler neck on a S4 TII center plate
These look SO MUCH better than they did when I sent them. Awesome work! I can't wait to get these back in my hands.
Old 08-03-2011, 10:34 AM   #59
To_Slow
One more set of 13b housings that got saved from the scraper by ChipsMotorsports.com
My link
Old 08-04-2011, 10:58 AM   #60
To_Slow
1 more set of plates to the list ... 13b plates
My link
