06-28-2011, 07:54 PM | #1 | |
Middle Iron Corrosion
I was doing final assembly, got to the middle iron and noticed corrosion. I have no clue when or how it got there. At first I thought it was damaged when I knocked the iron over and onto some tools while putting the front rotor in.
After closer inspection and even testing a bad iron by pushing it over onto the same tools. I found that it wasn't damaged when it fell over. The only thing I can think is that I sprayed all the parts off on Sunday. After sitting for almost 2 years they had gotten dusty, spider nests, etc. I tried cleaning the surface with some paint thinner but it won't come off. I can feel the marks with my finger. Obviously I'm concerned how they will affect compression? My thoughts are that they must be from hosing the parts off a couple days ago. I did not coat them with anything afterwards I was expecting to do the rebuild Sunday. It has to be recent, I can't believe that I'd miss something like that.
06-29-2011, 10:47 PM | #2 |
The oil film should mostly fill that corrosion near the port, although it is a crying shame that you didn't get some WD40 or oil on the housing right away to prevent that from happening.
I would be most worried about the corrosion in the oil control ring region. It appears that you used some type of water-based solvent to clean the housings, as the corrosion seems to track a drip path. Good center housings are about $50 on eBay typically. NA center housings are pretty common.
06-30-2011, 05:01 AM | #3 |
You can typically knock off this kinda of "surface rust" with some light oil and a fine grit sandpaper.
This should not affect compression in any way. This is the good news. The bad news is that Mazda gas-nitrides those surfaces for wear. Rust will usually eat through this gas-nitride surface, causing accelerated wear on the housing. -Ted |
06-30-2011, 06:46 AM | #4 |
Wee here at ChipsMotorsports.com can surface grind and re gas nitrate the plate for you.
Pics with info http://rotarycarclub.com/rotary_foru...ead.php?t=3109 Pricing http://www.chipsmotorsports.com/serv...d-re-nitriding Hope this helps. Chip U |
06-30-2011, 01:44 PM | #5 | ||||
The only things I used to clean any of the engine parts was Simple Green, acetone, when I ran out of acetone i switched to paint thinner. I did spray them down with water Sunday. Quote:
