Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
Any Good Carb tuners around Chicago?
Anyone know or recommend any good Carburated/Rotary tuners in or around Chicago/NW Indiana region?
what kind of carb do you have? what problems are you having?
![]() ![]() ![]() rotaryshack.com |
If you can drive it for a couple of hours, come on up for the race this Sunday. I'm not really an "expert", but I tend to get by okay.
![]() http://myautoevents.com/pls/mae/frmE...event_id=11856 .
I've got a Holley 650 DP on top and just don't like the motor turning over the numerous times it takes to start the car. I want it set just right for the one MAYBE two crank overs on initial start. The other problem is with the secondaries not kicking when giving it open throttle......you get the slight hesitation or bucking effect.
Btw,the motor is Bridgported. |
What do you have for ignition? If stock, then a stronger spark would be a step in the right direction.
Hmm, then I guess you're back to looking at the carb, or maybe ignition timing, or compression...
#9 |
Rep Power: 15 ![]() |
R u running a stock motor or rebuilt motor? The reason why i ask is because if it a rebuilt motor and u use after market apex seal spring that can cause what u are describing when ur trying to start. I have a great carb tuner he's coming in to Chicago at the end of July maybe he can check it out for u.
#10 |
Got another great race this weekend, July 2nd/3rd... Plenty of help for you up here.
Bookmarks |
Thread Tools | |
Display Modes | |
