#11 | |
Rep Power: 20 ![]() |
What I posted was a P-V diagram of the Otto Cycle (4-stroke cycle). The amount of pressure contained within the piston and the amount of volume it sweeps will be the only determining factor so long as combustion and heat rejection are kept the same. What you provided is only one part of the P-V. We'd still need the pressure it sees prior to combustion, after combustion, and the adiabatic expansion and heat rejection. Since no engine is ideal in the Otto Cycle the steps from compression up to combustion would be isentropic (it's a fair assumption; not great, but not as bad as adiabatic). After combustion it would be isentropic to the point of exhaustion--then depending on if there's a turbo in the way we'd have different pressures going on there. Intake would be dependent on stuff outside of the engine.
