		#61 | |||||||||
				Rep Power: 20 ![]()  |
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
		#62 |
			 Still Building my FD
				Rep Power: 17 ![]()  |
			wow.  very well thought out response.  I will definitely take much of this into consideration now.  (yes, I am admitting that my perspective on this topic has shifted a bit)
			My only argument would be that at this point, each rotor face could be considered the equivalent of a piston as to tdc and bdc. Or perhaps it is tdc/bdc of the crankshaft rotation since each piston or rotor face would be in a different position. These are just merely perspective questions to further define baseline definition and procedure and not to discredit or debase.
			Uh.... hi. Last edited by Monkman33; 06-06-2011 at 11:06 PM.  |
		#63 |
				Rep Power: 18 ![]()  |
			As I stated before, it is merely a difference in frame of reference. Each rotor housing undergoes one full cycle during each revolution, but each rotor face will require 3 rotations for a complete cycle.
			Because both the housing and the rotor are required to displace air, both frames of reference are valid. I think that Peter, Barry and Vex have done a very good job of illustrating the concepts that we all need to take away from this discussion. This is a good thread.
	1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic)  |
		#64 | |
 Yeah, I don't understand why people were getting all hot and bothered by this. The only thing I do not understand is where the 2.6L value comes from without using a multiplier. Anyone know?
		#65 |
				Rep Power: 16 ![]()  |
			Food for thought
	http://www.rotaryeng.net/Ansdale-displacement.pdf I´m inclined to 3.9 definition   Simply saying this is wankel engine and full engine is utilized only after 3 revolutions
		#66 |
			I would agree completely.  I cant think of any method that would make the 2.6l number viable.
	Uh.... hi.  |
		#67 | |
	(Using a VE of 100)it would be 654cc... and it would look like this, but the VE would actually be lower because of the still opened intake port and the trailing spark-plug hole spit-back. ![]() For a KX 500 2-stroke... 500cc... and it would look like blue bore depicted. It's actual VE would be much lower also because both intake and exhaust are open for part of the stroke (Consider what the effective compression ratio while starting). ![]() For the 2 liter Toyota…. 500cc For the 6 liter LS motor… 750 cc These pictures are mostly for the new guys that are a little afraid to raise their hands and get into the discussion... yet. I opened Rotarygod's web site. It is well done and he makes his case for 2X and 3X displacement, but you will notice that all references to the different engine sizes are exactly what the manufacturer calls them. This was the point of my initial post… if we don’t use a standard way of describing the Rotary’s displacement in our discussions we will be confusing ourselves, especially neophytes. Barry  |
		#68 |
			That's an idealized otto cycle Barry.  For all engines there's going to be descrepancies and variations from that.  I don't think there's a p-v diagram out ther for the 13B at least not to my knowledge.  I'll have to check the SAE papers.
		#69 |
			I still vote to compare apples to apples we use power/engine weight and/or size (physical, not displacement...).
	1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."  |
		#70 | |
		#71 | |
 ![]() Bare engine may appear compact and light, but whole package is what counts. Engine, intake and exhaust manifolds, cooling system, muffler system, it all counts. We can´t just say that certain engine is compact and light, when all needed accessories through their bulk and added weight doesn´t make it such viable powerplant. I would look for advantages of wankel rotary elsewhere  |
		#72 |
			I understand your reasoning but doesn´t such approach ignores that rotor housing has two TDCs and BDCs?
	Common sense would tell that we examine only intake part, but who knows ![]() I think that wankel engine should be treated as wankel - whole termodynamic cycle is completed only after 3 revolutions. And of course 3 such cycles will be completed, just shifted by 360°.  |
		#73 | |
 Why do we care again about the thermodynamic cycle or how many revolutions it's completed in; when we're worried about displacement?
		#74 | |
			 I have radioactive semen
			no, i was familiar with the term. i had just never seen the graph you posted and i figured i would spend hours trying to get, but after looking at it that night, i had it in less than an hour and confirmed my understanding of it via Wikipedia (for what that's worth - wink, wink
	 )Quote:
 ![]() as i understand it, they are using a multiplier - based on the 720 degree theory. by itself, it does seem arbitrary though. it's funny, when i first got into rotaries (back in the mid 80s), some people used to say two rotor engines were equal to 2.4 liter, 4 cylinder engines (most people i knew primarily messed with 12As at the time), but extending that way of thinking to a 13B, you'd get 2.6L. the thinking was that rotaries were more akin to 2-strokes in nature, so they multiplied by 2. i don't know where the 4 cylinder thing came from. if you are inclined to think of each rotor face as cylinders (which i know you don't), then with a 2.6L 4-banger, you have exactly two-thirds of a 3.9L 6. so in that context, i guess it makes sense ... sort of. come to think of it, i think i just found the 2616 theory less valid.  |
		#75 | |
 The piston engine's rod ratio will affect its shape vs. the Rotary's sine wave movement. (Dotted line-rotary, from Yamamoto's book)
