Old 05-06-2011, 04:50 PM   #1
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
Suggestions on when to do a rebuild
Well, I was going to post this in the 8 forum, but I figure the information is prolly universal. And I did attempt a search on this, but didn't come up with anything constructive.
So the question is this: I have a 05 rx-8 with 90k on it, original motor. I have premixed since about 70k, and have used only 20w 50 since I got the car. Currently there does not seem to be any issue with the motor; It idles fine, and performed like a champ at DGRR. From what I have heard, when it comes time for a rebuild, at least one item (rotor, housing, etc) needs to be replaced, depending on the failure mode. So what I am wondering is, would it be beneficial to tear down the motor and rebuild it BEFORE it failed? I would assume it could potentially save a bit of cash doing it this way. If anyone else does this, about what mileage would be suggested?
Thoughts?
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 05-06-2011, 06:28 PM   #2
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
I would not rebuild it until something gives way, coolant / oil seal or compression seal etc.
Unless I wanted to upgrade the internals. Porting, etc.
Just take care of it and it should go a long way.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 05-06-2011, 11:36 PM   #3
NoDOHC
NoDOHC's Avatar
If you are running non-turbo, they will typically give some indication of age before they let go. With a Turbo, you could destroy a new engine as easily as an old one, so there is really no major advantage to a rebuild there either.
If compression is good, you are probably Ok to keep running it. It will probably start flooding and idling a little rough long before you have any actual failures.
Old 05-07-2011, 12:12 AM   #4
These men speak the truth. N/A's can and do go a loooooooooooooooooooooooooooong time. If it ain't broke, don't fix it.
The problem is, with the mileage you're at, and the fact that you've only been pre-mixing for 20k, those housings probably aren't reuseable anyway, at least not highly useable if that makes any sense.....
Old 05-07-2011, 12:23 AM   #5
project86
Can't.Make.Up.My.Mind.
project86's Avatar
ya my fc had 140k on it when i tore it down. after looking over alot of the parts im surprised at how well it ran... corner seals were f***** i had gouges in rotors and gouges on the leading edges of ports. i was getting some smoke but i think it was primarily from premix.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
