#8 | |
Then I saw a rotary that pressurized the crankcase when revved, it turned out to have a worn out spring under the inner oil control ring (the ring had been spinning relative to the spring - the spring tab apparently was not installed correctly). This disproved my theory about the combustion by-products leaking past the side seals, as only combustion by-products or pre-combustion compressed air (coming from same chamber) could pressurize the crankcase. These findings would tend to reinforce that oil dilution is possible, only I haven't seen it. What conditions will cause oil dilution? Does it have to be rich-misfiring? I never let an engine run rich of 13:1 (in vacuum), as this will wash the oil film off the seals and decrease compression, accelerate wear and waste fuel for no reason. On a piston engine sometimes you have to run rich to protect valvetrain, but the rotary is immune to burned exhaust valves (although not exhaust sleeve failure).
