Old 04-16-2011, 11:19 AM   #11
2gslse
No worries man, those are some damn good numbers indeed. Are you taking that setup and dropping it in the FB? That would be soooooooooooo money. What wastegate are you running?[/QUOTE]
Yes it is the set-up for the FB the only changes are I will be using a 13B-RE and the later version RX6 turbo that uses a short runner manifold (I will have to clearance the lower manifold a little bit since the compressor just touches the RE lower) I already have the engine, the S4 N/A rotors I got from you, turbo kit from another FD, huge front mount intercooler and the Haltech platinum 1000 sitting here so most of my build is waiting for a little more money and a lot of time. hoping to crack 400 hp in a 2500lb car so it should be a rocket until the diff explodes
The wastegate is the one that came with the kit its an Apexi also but they have had a few failures on them in the past the bushing binds on the shaft when they get hot so all I need to do is bore out the bushing a tiny bit Dave said he has seen it before with that gate so I'll do both of mine at the same time
2006 VW TDI commuter
