Old 03-29-2011, 06:42 PM   #23
NoDOHC
NoDOHC's Avatar
Fred, you are awesome! Going to that much work to test a theory.
The reason that the blocking diode is in the circuit is that if the 8 gauge alternator output wire were to fall off, the alternator would attempt to charge the battery and operate all the electrical components in the car through the W/B wire and the warning light coil. The diode prevents this.
The 11.5 Volts is not normal at all. The L and S terminals should both be reading somewhere near the alternator output voltage.
