#1 | ||
Rep Power: 20 ![]() |
Water obeys the same fundamental laws as air does (energy, mass, and momentum). Hence why both mediums have circulation, currents, laminar and turbulent flows, etc, etc, etc. They both flow exactly the same. As I stated earlier you can prove this by solving for the Reynolds Number (which is a dimensionless number that accounts for the various medium's density) and applying it to both water and air. The results will be exactly the same. In fact, this is how engineers do various testing. Quote:
#2 | |
Rep Power: 15 ![]() |
I'm asking not because I'm doubtful of the previously mentioned method of water injection. I'm primarily putting forth these questions for more clarification when considering the accuracy of flow testing results. I don't want to settle because it's what's been accepted for ions. It would be better to scrutinize and challenge the findings and let them stand on their own merits rather than what's spouted/parroted off by a lineage of engineers in an informal daisy chain if you know what I mean. The world is much too dynamic to take it for granted that it's ALWAYS going to do what's expected every time. |
Rep Power: 10 ![]() ![]() |
I agree with you. I'm in Molecular Bio/Genetics and things that worked 10 years ago now doesn't work. Physics, chemistry, etc... in theory a lot stands in place, but some just doesn't work in the real world.
#4 | |
All flow experiments and research have only reinforced what was first discovered all those years ago by people by the name of: Bernoulli Mach Reynolds Froude Just to name a few. Unless something drastic were to happen tomorrow such as the laws of Thermo Dynamics were found to be wrong, the flow laws and mathematics will remain intact.
#5 | |||
Back to the proposed comment "Water does not flow like air" is absolutely false. Point in fact the original exploration of air flow was done with water and the results extrapolated out to air, which was then tested and confirmed. Now-a-days with the proper instruments and technical ability we can test air independent of water, however, what we learn from air only reinforces what we already have known. That is, if you solve for a particular flow using the Reynolds number you can match any medium you want to the same exact flow. This means I can not only match water and air, but I could also match oil, nitrogen, helium, oxygen, etc, etc, etc. Here's something to consider: Air (mostly composed of nitrogen, and so nitrogen is used), has a molecular weight of 14.0067 g/mol, and water has a molecular weight of (1.00794 g/mol)*2+ 15.9994 g/mol (or 18.01528 g/mol), flow exactly the same. However if we take the hypothesis of "water does not flow like air" we by extension must emphatically state that the components of water do not flow like air. This means hydrogen and oxygen do not follow the same laws as nitrogen. This is obviously false, as both hydrogen and oxygen flow exactly the same as nitrogen when one matches the Reynolds number. Since water is a Newtonian fluid as well one can do the same. Another thought experiment; what if water was turned gaseous? Would the flow be any different? No. The medium is water, but just in its gaseous state. One need only match the Reynolds number and the flows will be exact. Now for turbulent flows: Turbulent flows are a bit harder to model as they are equivalent to white noise in radio. They therefore remain random when looked at molecular level Eulerian perspective. This means statistical analysis is done on the medium using various fluid properties (and other boundary conditions) to determine the numerical basis of the turbulent region of concern. What I'm basically saying is that all Newtonian fluids that experience a turbulent region of flow will behave exactly the same. This means that when the Re is matched, the flow (regardless of density) remains the same. Turbulent Boundary regions, Turbulent flows, Laminar Flows, they flow the same. This is how fluids work. The exceptions to this rule however do exist. They include super fluids, or fluids that have almost no viscosity. These fluids are never used inside of commercial engines and play no part in the discussion at hand, but they do bear mentioning. They do not behave the same as regular Newtonian fluids. For more information concerning these fluids I suggest reading the wiki-article concerning them.
#6 | |
FC3S
You must have missed reading those parts. |
Not at all. It's called dotting your "I's" and crossing your "T's".
"Knowledge" can be bad for the ego apparently: by puffing it up and giving those who have gained any information from others a false sense of self-importance. "Stupid" questions should be asked along with the "Not-So-Stupid" questions. That way you can better distinguish between them. Especially so in a public forum so that others can witness the difference and avoid repeating them. Off to find wisdom somewhere else. I'm sure there are more people out in the internets that are wrong that ya'll need to take care of or something... |
