Old 03-22-2011, 10:03 PM   #3
RX SE7EN
RX SE7EN is on a distinguished road
This will completely replace all OEM Oil lines with SS line & AN fittings using the dual OEM oil coolers. No fitment issues with A/C. Be sure to cover the SS lines with plastic loom at possible rub points.
http://www.batinc.net/
OIL COOLER FITTINGS………………………………………..........................P ART#............PRICE
4.... Male 22 MM X1.5 MM metric concave seat -10 AN aluminum...AM22AN10......12.95--- 51.80
13 ft -10 aeroquip line.............................................. .................FC3-10..............6.50---84.50
2.... 45 degree alu -10 hose end............................................... ....T45-10.............18.75---37.50
2.... straight alu -10 hose end............................................... ........TS-10.................8.95---17.90
1.... male 18 MM X 1.5 Metric concave seat to -10 AN steel...........AM18AN10.........9.85
2.... 90 degree alum -10 hose end............................................... .T90-10.............37.50
1.... "Metric Banjo -AN Male"............................................. .............BJ1810M..........30.15
1.... banjo bolt.............................................. .................................BJBM18........... .11.90
2.... seals............................................. ..........................................DS-M18................80--- 1.60
$282.70
You can get most of the fittings (except the banjo fittings and AN to metric adapters) from Summit racing cheaper. They have some AN to metric adapters but not the right size, and they don't have a good selection of banjo fittings.
I would also get the braided hose from Summit, its cheaper there too, especially the Braided Nylon Hose.
RX SE7EN is offline   Reply With Quote
