| Fabrication Show off the parts that you've built from scratch or highly modified |
|  02-11-2011, 12:33 PM | #61 |
| I-had-a-bad-experience... Join Date: Feb 2008 Location: M'boro
				Rep Power: 19  |
			I'm at work so I'm not clicking on that link
				__________________ '15 Juke Nismo '06 MX-5 GT SOLD '04 S Silver RX-8 GT Track Day Use SOLD '90 Black TII vert w/ Sprint RE stock port/turbo DD dyno (242.6whp@5500rpm @12psi 8psi@redline) and (250ftlbtq@4800rpm @13psi) SOLD '89 GTUs 6p TII SOLD, '87 sport SOLD, '79 SA stock SOLD '91 B2600i 4x4 w/ Rx-8 LSD SOLD |
|  02-11-2011, 01:21 PM | #62 |
| Sigh..... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 20  |
			Surprisingly it's actually a safe link.  However, it's a terrible name for a company.
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." |
|  02-11-2011, 02:26 PM | #63 |
				Rep Power: 19  |
			or is it?
|  02-11-2011, 02:46 PM | #64 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |
			We sub contract out to a REALLY heavy, really unkempt guy who calls his company  Fiberglass And Repair Technology
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  02-24-2011, 12:15 PM | #65 |
| RCC Loves Me Not You Join Date: Jul 2008 Location: Influx.
				Rep Power: 20  |
			So back on topic:  When wiring in multiple coil/igniter's for the ignition system what is the standard practice to wire in the ECU 12V lead? Should one use a Junction or power distribution block to split the lead into 4 or more other coils, or should one use multiple op-amp's and solder them in?
				__________________ The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group |
|  02-24-2011, 03:35 PM | #66 |
				Rep Power: 10  |
			How is an old, fat, unshaven, irregular showerer who calls his company FART not on topic?    Here's what I do.... I use the B/Y wire from the main fuse block, EGI fuse I BELIEVE as the turn on for the relay thaty powers the ECU.... It's also used as the turn on for the radio, the GPS, Sirius etc etc etc etc... Which ever ciruit you use, it needs to be hot when cranking. Wire the relay directly to the bat through a breaker/fuse. For the ignition system, injectors, fuel pump etc, I use the Fuel Pump Relay option in the Motec. It's adjustable for time on, delay, whatever. This output triggers the relays that turn on power for the injectors, ignition, solenoids, etc. Each has their own fuse and relay.
|  02-24-2011, 05:21 PM | #67 | |
				Rep Power: 20  | Quote:
				__________________ The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group | |
|  02-24-2011, 07:28 PM | #68 |
				Rep Power: 10  |
			Stepdown buttconnectors... one 12ish gaughe wire goes in, 4 18 ga wires come out.  Crimp and you're done homer.
|  02-25-2011, 12:16 PM | #69 | |
 I'll post my plan in better detail in my ShowOff Thread.
|  02-25-2011, 01:20 PM | #70 |
				Rep Power: 10  |
			I wouldn't use weatherpack... personal preference is for metripack.  In the case of anything fuel or ignition related though, I always use Deutsch connectors though.
|  02-25-2011, 02:20 PM | #71 |
				Rep Power: 20  |
			Is there a particular reason why one plug is better applied than another?
|  02-25-2011, 02:26 PM | #72 |
				Rep Power: 10  |
			Weatherpack is bigger and bulkier but they can take more Amps. Metrpack is smaller, takes less amps buit I like thier pins more. Deutsch has the best pins, best sealing, and as a bonus you can get them with the extended lip on the back and get some 4:1 heatshrink and have a totally sealed connector. Amps kinda vary with all of them as you can get a bigger series Metripack to handle more amps. But, there is nothing on an engine that requires the 25A that the weatherpacks allow.
|  02-25-2011, 04:16 PM | #73 |
				Rep Power: 20  |
|  02-25-2011, 04:22 PM | #74 |
				Rep Power: 10  |
			Cool.... I go to Batts Racing... I'll compare prices later..
|  02-27-2011, 12:15 AM | #75 |
| Rotary Fan in Training Join Date: Jun 2008
				Rep Power: 0  |
			Where do you guys order your wire from? I placed a huge order with Polar Wire, which is a machine service/arctic rated wire and crimps. I wanted to try it out after my brother re-wired his motorcycle with it and has been incredibly happy. Its 1/2 the price of TXL rated wire I can find through google, and offers very similar qualities. Same goes for the copper tinned crimps. I also just bought one of the ebay $70 480 piece 3m heatshrink connector sets. Cant wait to get it in. |
