Old 02-10-2011, 03:27 PM   #1
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default Falcore
Well that's what i named him, yeah my car is a him. When i was going to buy the car most of my friends and family told me not to. So why not name it after a luck dragon. Anyways here's what it's gone through so far.
I bought it in April of 05 and my aim was for 400hp by 2011. It is now 2011 and i'm close (I think) but not quite there.
When i first got him home
I think i had it a full 2 days before i was already taking it apart Koyo rad install
5th gear sycro and full tranny rebuild.
There's my problem
Then i went to a Pettit ECU and underdrive Waterpump pully and Alt pully
Battery relocation
FMIC and AVC-R install
Had to do some cutting to get the FMIC to fit
Supra TT fuel pump
HKS intakes and B&M short shifter
Had to polish the intakes....cuz that's important right :bigrolleyes:
B&M
Dropped a few lbs with an HKS carbon TI exhaust
Then i went with Whiteline/noltec rear diff bushings
Old ones cracked and leaking crap
Just before i started taking everything apart for Haltech platnum 1000, Escalade coils, AEM wideband, 99spec twins
My buddy that was helping me with my haltech was also building a 1.5jz....lube that shaft
So many wires
Old on left new on right
Fins on old turbo
fins on new turbo
Done
Was getting some boost creep after midpipe install so i had to pull the turbos and port/grind out metal behind the WG flaper
Before
After
I sprayed it pink so i could see how much i could take out and PINK MEENS DANGER!
I forgot to take an after pic
Last thing i did was a new gauge for Water temp, Oil temp, Oil pres
Again with the wires
Done. Remote is for Peak recal, color change, C to F, set alams and so forth
Clean piston
Steal braded brake lines
I'm taking the calipers to be powder coated then everything will go back together.
powder coater Calipers
Fuel system is Rx7stores Ultimate fuel system. 850primarys and 1600secondarys Aeromotive FPR.
Injetor Rehab blueprint
Meth system, i'm hopping to start this on the 6th
Old 02-10-2011, 03:32 PM   #2
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Since heat is the enemy double so in a rotary i heat insulated the underside of the UIM. As things go for time consumption Polishing is #1 this takes a close 2nd.
Clean the ever living snot out of the UIM get every last piece of grease i can possibly scrub off of it
Start application
Finish
The Fuel system took me a while. I spent to much time cleaning.
Switched to MSD coils for primarys and Escalade coils for secondarys
Old 02-10-2011, 03:33 PM   #3
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Got a bracket made for the coils and reloomed them up
I hate....HATE wiring fuuuuuu
And my aluminum door handles came in. The FD's stock plastic door handles suck big floppy donkey dick. Over time they'll warp or break. My driver side handle is warped and wont push the pin far enough down to open the door.
Old 02-10-2011, 03:39 PM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Bought from dudemaaan on this forum.
RE hood struts
Ended up changing the fuel system around. I was told hooking the feed up to the secondary rail was better so that's the way i went. If you have any suggestions let me know.
Pump mounted
Meth line i wrapped it since braided lines have a tendency to eat through things
So i first tried to put the novel in the black coupler i had only problem is it's to thick and i couldn't thread on the backing to seal the coupler
So i had to use an old blue coupler i had that's a bit smaller i'm sure it will work right but i need to find something else. You can see the silver washer looking thing on the blue i couldn't get that piece on the black coupler
Fixed
Pressure light Red when building Green when on
Low level light
Fuse block for pump
Main power and main ground just left to run and a retune yaaa
Old 02-10-2011, 03:44 PM   #5
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
My first Dyno season was fun but my car was being a POS. First off i drove all the way to Palm springs on 1 rotor. Yeah i screwed up some wiring on my coils so 1 rotor was not working. Lets just say it was 1 of the most painful drives i have ever made. I felt like a Top Gear presenter, you know when they screw up and cars are all backed up behind them. Yeah that was me Laughing
I made it to my buddy's house at like 11:45 we got the coil issue figured out by like 130 ish and did some street tuning. During our street tune i'm sitting passenger seat. Glenn's (my friend) is doing like 100 and i see a little bunny come bounding out of the desert. I calmly say "Bunny" it runs out and runs smack into the side of my car Glenn barely swerved which i thanked him for, plow that stupid bunny don't spin us out into the desert at 100mph. I start laughing my ass off we go down and come back doing another pull and the bunny was gone. The fucker lived after running smack into the side of my car. We didn't get done tell like 3:00am. I woke up at like 530am and couldn't go back to sleep. We ended up leaving for the Dyno at like 730.
Dyno session didn't pan out though my car was being a little bitch. The ECU kept disconnecting from the laptop as soon as they started going. It was pulling hard friday night when we were street tuning it. I'm really not sure what's wrong with it. Here is the best video of my car from Saturday.
http://www.youtube.com/watch?v=xnP0cQ_jKDI
FIRE
We tried for about an hour and a half to get it to act like it's suppose to and it never did. The best pull i got was a 203hp at 6k rpm's Crying or Very sad The dyno graph was very sergey and all over the place. Hopefully i'll have it figured out by next month and do another dyno season.
Old 02-10-2011, 03:47 PM   #6
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
New tires YAAAAAAAAAAA my Volks can go back on finally dam ugly AVS rims are getting taken off. The back of my truck right now.
Old 02-10-2011, 03:50 PM   #7
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Rolling shots from Seven Stock i really need to get some body work done.
Old 02-10-2011, 03:52 PM   #8
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Got myself a new used clutch still haven't mounted it yet.
Finally got a trans cover. My car had been missing it since i bought it found it on ebay for 20$
Also did some work on the interior lights. For some reason Mazda thought black was a good color for reflecting light inside the car. So i took them apart and painted them and put in an LED bulb holly crap it's like day time in my car now.
Old 02-10-2011, 03:56 PM   #9
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Finally got my fenders rolled and dropped the car 1.5inches all around
Before
After
Car also got himself a new home
Got a custom splitter made
Also started working on new bushings.
Before
After
Before
After
Got my steering rack bushings in what a PITA. Since i don't have new pillow balls yet it will be a while before i have the bushings pressed. I'm not in any hurry.
Old 02-10-2011, 04:21 PM   #10
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Default
Preliminary mount stuck out way to far.
Fixed
That's it so far...i think
Old 02-10-2011, 09:06 PM   #11
Duffman692002
Member of the D club
Duffman692002's Avatar
Duffman692002 is on a distinguished road
Default
Lookin' good.
Follow my Spark Yellow restoration:
http://www.rotarycarclub.com/rotary_...ad.php?t=12726
Duffman692002 is offline   Reply With Quote
Old 02-10-2011, 10:02 PM   #12
Default
You're gay, or your cars gay.... cars are she's.... like boats..... and for good reasons
Glad to see you over here Tyler. Car looks awesome, now bring it to Deals! Or at least yourself.
Old 02-10-2011, 10:02 PM   #13
Default
Old 02-10-2011, 10:11 PM   #14
Default
Sooo.....all that work and rocking a 6spd RX-8 knob?
You need to go to Rotary Performance and get one of their 5spd RX-8 knobs.
Just giving you hell, great build!
Old 02-10-2011, 10:28 PM   #15
Default
I rock an RX8 6-spd....knob...... What are ya trying to say DJ?
Ad Management by RedTyger
