|  02-10-2011, 12:10 AM | #1 |
| RCC Loves Me Not You Join Date: Mar 2008 Location: Eagleville, TN
				Rep Power: 20  |  Eccentric Shaft End Play?
			The specifications within my Haynes manual specify that the "Standard" is .04 to .07 mm with a max of .09 mm. I started off with my "K" spacer and had a reading on my dial gauge of .015  (give or take .002 mm). I felt that may have been a little too tight so I borrowed an "X" spacer from jfaplanet and received a reading of .02 mm (maybe .002 mm more). IIRC the "S" and "T" spacers are uncommon and was wondering if the reading I received from the "X" (.02?) was good enough, or is it too tight still? ? ?
				__________________ 1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
|  02-10-2011, 12:28 AM | #2 |
				Rep Power: 20  |
|  02-10-2011, 12:38 AM | #3 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |
			.0015" is what I shoot for.  Basically a little tighter than Mazda's min.  What are you torqueing the front nut to?  You know you can tighten it a little more to snub it up a wee bit.  I usually go for 110-115ft/lbs.
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  02-10-2011, 03:01 AM | #4 |
				Rep Power: 20  |
			I didn't torque it at all, just ran a battery impact on it and the rear nut for a few seconds (probably around 90-100ft/lbs given the tools specs) just for fitment purposes but now that you mention it I can see the specified torque being crucial to the fitment process. Only thing is, is that will possibly get me a little less play. If you successfully run yours with a run-out of .0015mm with no issue then I'll stay with the "K" where I had the initial .015mm run-out and of coarse rechecking it after properly torquing the front and rear.
|  02-10-2011, 06:27 AM | #5 |
				Rep Power: 20  |
			Sorry TT, misunderstanding on my part. I now see that you were stating your measurement in inches which is .038mm. So now my question is,  Who has a "S" or "T" spacer? Can these be purchased from Mazda still?
|  02-10-2011, 08:18 AM | #6 |
				Rep Power: 10  |
			Are you sure those are in mm and not inches?  I can't tell from the vid.  It's rare that spacers need to be changed out.... unless you changed bearings or rotors....  I'd try Rob @ Pineapple.  He told me once that he has a drawer full of them if I needed an odd size.  MT probably has them as well and I'm sure Ray Crowe can get them as well.
|  02-10-2011, 10:04 AM | #7 |
				Rep Power: 20  |
			Yeah, all new bearings (came in the RX8 stat. gears). Just ordered some spacers from Atkins, got both S & T to be sure.
|  02-10-2011, 10:42 AM | #8 |
| Sigh..... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 20  |
			So to clarify Zach, the issue is that your shaft isn't getting enough play?
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." |
|  02-10-2011, 10:54 AM | #9 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  02-10-2011, 11:32 AM | #10 |
				Rep Power: 10  |
			Zing!
|  02-10-2011, 07:13 PM | #11 |
				Rep Power: 20  |
			Wow! Should've seen that commin
|  02-10-2011, 07:33 PM | #12 |
				Rep Power: 10  |
|  02-10-2011, 11:01 PM | #13 |
				Rep Power: 20  |
|  02-11-2011, 07:57 AM | #14 |
				Rep Power: 20  |
|  02-11-2011, 01:02 PM | #15 |
				Rep Power: 22  |
			Leave it to this group to turn a serious thread into a dick and fart joke. poop
