Old 01-23-2011, 04:32 PM   #1
Thumper
Backyard Mechanic
Thumper's Avatar
Thumper is on a distinguished road
Default FPR Vacuum
Ok I'm sure that this has been covered 100 times before, but I tried searching and came up with nothing. I've removed the rats nest on my S4 NA now where do i hook the fpr vacuum hose? Can I just connect it to the DC? Also what are you guys doing with the line running from the charcoal canister?
Thumper is offline   Reply With Quote
Old 01-24-2011, 01:53 AM   #2
Default
FPR vacuum line can go anywhere *after* the throttle body - it has to see vacuum at idle, or else it'll run rich (at idle).
I still have my charcoal hooked up for emissions sake.
Old 01-24-2011, 11:39 PM   #3
NoDOHC
NoDOHC's Avatar
Default
The charcoal canister line typically runs to the port near the oil fill on the engine. I could get you a picture, but my one car is far from stock and the other is covered in snow.
The vacuum bias line on the FPR is required to keep the pressure that the injectors see constant (linear injection quantity at all manifold pressures). Because the bottom of the injectors see manifold vacuum, the effective pressure seen by the injector is rail pressure + manifold vacuum. If the rail pressure remains constant, you will see a very rich idle (9 psi vacuum + 42 psi fuel pressure = 51psi). SQRT(51/42) = 1.10 = 10% increase in fueling at idle.
As Ted said, anywhere after the throttle plate is good. I connect mine as close to the actual injectors as possible, but it doesn't really make a difference.
Ad Management by RedTyger
