| 3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
FS.2000cc Bosch injectors
Up for sale 2000cc injectors i have like 100 injectors..
These are not modified to flow that amount they come standard from Bosch. Bosch EV14 Injector with top adapter. Flow rate 2000 cc /min @3 bar, 8.5 ohm. Sumitomo (NDCON1) connector, total lenght 74 mm, distance between O-rings 61 mm. 1600 cc /2 bar, 2400 cc /4 bar. Much cheaper than any site out there. The same injectors from Injector Dynamics 2000cc Price per 185.00$ Shipped... |
addicted to boost
these are high impedance correct? Do they come with the pigtails? Do you also have the 725s or 1000s? Would you do a discount if I purchased 2 1000s and 2 2000s?
#3 | |
1000cc can have them in a couple of days 98.00 per . Sorry i cannot do deals they are pretty cheap.. |
Rep Power: 20 ![]() |
As long as these are the exact same injectors and setups, that's a better deal than I've found anywhere else, and I just bought a set not too long ago haha.
#6 | |
Boricua!
if one buys them in pairs, are they flow matched? do they include flow and latency numbers?
What kind of deal can you get for 2-750 and 2-1000 LI injectors with clips and tails? LMKS thanks Joshua.
#9 | |
Yes, they wil come with a flow sheet that will show they are matching flow rates. Last edited by To_Slow; 01-15-2011 at 05:18 PM. |
#10 |
You got mail...
#11 |
so the injectors you areoffering are plug & play for the fd3s just like the ones being sold by injector dynamics? practicaly what I'm asking is: are these exactly the same thing at a cheaper price?
#12 | |
Then ID just re brands them as there injector. The part # for Bosch 2000cc injector is # 0280158821 That is correct, i provide the same injectors as ID at a realistic price, not the over inflated price of 220.00 per. Yes they identical Coil Resistance: 9.1 Ohms / High Impedance Dead Time: 0.45ms at 14 volts Static Flow Rate @ 43.5 PSI ( 300kPa ) w/Gas: 2200 cc/min = 210 lb/hr Static Flow Rate @ 58 PSI ( 400kPa ) w/Gas: 2550 cc/min = 240 lb/hr Static Flow Rate @ 78.5 PSI ( 500kPa ) w/Gas: 2865 cc/min = 273 lb/hr Static Flow Rate @ 88 PSI ( 600kPa ) w/Gas: 3155 cc/min = 300 lb/hr Static Flow Rate @ 101.5PSI ( 700kPa ) w/Gas: 3350 cc/min = 320 lb/hr Connector: Denso / Sumitomo Injector Length: O-Ring to O-Ring: 1.5. / 37.5 mm Injector Body Diameter: 16mm O-Ring: 14.5mm Viton Acceptable Fuels: Gas/Petrol, alcohol/methanol, E85, CNG Yes they are plug in play with no need of resistors, with the help of a aftermarket ECU like PFC Etc.. Thanks |
#14 |
ID matches the injectors based on flow AND dead times, do you do the same? Do you provide data with them? If not, they are NOT the same.
#15 | |
I don't think the dead time /flow sheet is worth the 150.00+ I have looked at customer's flow /dat sheet from ID for 2000cc injectors they are all the same, what stops ID from just coping the same flow sheet and sending it out with the same injectors... I'm not pointing fingers or making the above a true actual fact, other than taking ID word that they have been flowed/dead times etc.. I hope you understand my point of view... But yes Bosch NIG 2000cc injectors are the same as ID injectors,, the flow sheet is not the same.... Thanks Last edited by To_Slow; 03-28-2011 at 09:51 AM. |
