Old 12-28-2010, 07:31 PM   #39
Originally Posted by josh18_2k View Post
brian- i wouldnt bother with the toe links. MMR's spherical control arm bearings retain the OEM toe adjuster so there's really no need.
i also prefer MMR's individual camber adjusters as it incorporates a rod end. AWR/Mazdatric links have metal sleeves on both ends, and the control arm movement isnt completely uniaxial.
anything between 1-1.5* rear camber is fine for a street car. 1 is probably ideal. i run 1.5* with 315 v710s and get even tire temps.
Thanks Josh, I appreciate it. I'll have to take a peak at those. Something's a little messed up in the rear and I see about a 1/4* difference in rear camber. Although the rear is pretty well dialed in, just need to really dial in the front
Come on B, you're slacking and still slow.
And you're still gay for not trotting over to Bills!
I incite the BAN HAMMAR due to provoking a mod!
Mod??? Please.... Admin foo!!!!!
