Rep Power: 10 ![]() |
Have it
Use it Love it I think at times it's soaking the engine with oil. I run the OMP through the MoTeC with a map that was reverse engineered by a MoTeC and rotary guru to match the factory OMP. I run Idemitsu premix and toss 1/4 oz/gal of gas in the tank as well just for good measure. This is just my thought, my feelings, and as I said, I feel as if I am saturating the engine sometimes but if you think about the two cons of both systems - Factory MOP - not very good despersion. Anyone who has torn down an engine that only ran the MOP will know what I mean Pre-mix only - ZERO lube on decel............ take that as you will. Phil and I actually had an interesting conversation on this a while back. Anyway, by both pre-mixing and running the MOP, I fell I get the best of both worlds. It's 2x the PITA, but whatever I have an RE, I have REW twins, I also have the REW waterpump housing. Jeff is correct, I mounted mine where the air-pump once lived. I also built my own tank out of AL with a really sexy pop-up gas tank fill from a motorcycle supply house. RA/Sohn calls for it to be 6" (IIRC) above the OMP. And it needs to be gravity fed obviously. I would keep the length as short as possible however Hailers once did a test by putting his resevoir on the ground and watched the pump self prime under vacuum. I would have to say that the output of the pump from a vac vs a slight pressure would be very different and that 6" of pressure mimics the small amount of "pressure" that the pump sees from the front cover.
