Go Back   Rotary Car Club > Motorsports and Events > Drifting
Drifting All things sideways
Old 11-25-2010, 12:09 PM   #1
classicauto
crash auto?fix auto
classicauto's Avatar
Originally Posted by iani1.1 View Post
i understand your type of motor sports. here's an example
makes dicks hard due to "performance"
makes pussy's wet cause shit looks ill
Holy fawk you are hopeless BOY.
1: You're a JTP fan boi. The only pussy getting wet looking at that car is yours.
2: The wheels DO NOT fit because you need to run improper width tires for the rims. Earlier you asked how stretching tires could possibly be bad. If you have to ask that question you've obviously never paid attention to a tire manufacturer's recommended sizing chart. And no - the chart is not what the "think" works, its based on road force testing to the speed rating of the tires, and running too narrow or too wide can cause a variety of issues.
3: This is not about X vs Y or someone's opinion on what looks good or makes fan boi pussy wet. This is about will the wheel fit with no stretch and the answer is that it won't.
4: If you don't understand the reason to check suspension travel for wheel clearance then well.......that illustrates your lack of understanding. When you installed the knuckles from you idol JTP - did you check clearance from lock to lock? You probably did because you're probably going to use the extended travel.................if you ever plan on hitting any bumps in the road (and aren't running 15K springs like the rest of the fanbois) you will use your full suspension travel - or at least more then you will if you simply drop your coils for cool pictars to wet other fan boy va jay jays.
5: I love drifting. Its alot of fun. Whats not fun is being a mindless follower. You can admit that the wheels don't fit now. And no - I'm not a mindless follower by jumping on the myriad of people disagreeing with you - I'm MINDFUL because I know the wheels the OP is asking about do not fit a stock bodied FC without a slew of modifcations and stretched tires. End of discussion.
Thank you come again!
