If your '7 still has the stock wiring harness, I would recommend installing both rails on the motor, jumper the yellow fuel pressure test connector (located by the passenger side strut tower). When you switch the key to run, you'll hear the fuel pump running and will know in a hurry if/where it's leaking from.
