Old 11-19-2010, 07:05 PM   #14
NoDOHC
NoDOHC's Avatar
Ted is right about the crimps vs. Solder. The Solder makes a good connection - electrically, but the wires get bent a lot more on the edges of the solder and it is much more likely to fail - mechanically. The OEMs all run a single wire from point A to point B. Where I have seen a splice in an OEM harness, it has been crimped and sealed. There is a reason that they do it this way and it isn't cost. Sealing is critical to avoid corrosion on crimp connectors.
