|  11-19-2010, 05:09 PM | #1 |
| Rotary Fan in Training Join Date: Nov 2009 Location: idaho
				Rep Power: 0  |
				help, looking to build a bad a$$ 6-port?
			I'm looking for help on building a high hp 6-port N/A.  all S4 parts. atkin's seals, ran by a haltech e6k. wanting the largest usable rev range. which i know is hard, but alway's wanted.  this will be for complete PLAY.  drag/auto-x, possible drift. options street port vs sec bridge vs full bridge? s4 n/a vs s4t2 vs complete rew w/adaptor plate at block aux port will have custom inserts to help ramp the air flow looking for comments on how someone else would build one as far as custom intake, help with the design and i will build it! thanks Scott,(RX200013B)
				__________________ ULTIMATE N/A |
|  11-19-2010, 05:40 PM | #2 |
| The quest for more torque Join Date: Sep 2008 Location: Sheboygan, Wisconsin
				Rep Power: 18  |
			Your biggest power adder would be a custom intake. I think that the lower part of the factory one could be modified to be passable, but the upper part has to go. I would recommend not using S4 parts, but S5. The rotors have better compression and are lighter. What power levels are you looking for? I have heard of an Aux Port Bridge, which will help the high end appreciably while maintaining some semblance of low end torque (not a bridge port until the sleeves open). Unfortunately, I have never had the opportunity to build a maximum effort 6-port, but my mildly ported 4-port has 60 WHp and 60Wlb-ft on the best 6-port build I had (Haltech E6X, stock - polished intake manifold, port matched with custom cold air intake - no AFM, stock S4 block), Racing beat headers, 4-port vs. 6-port 216 WHp vs. 155 WHp 160 Wlb-ft vs. 100 Wlb-ft.  Short story is the the 4-port has a lot more potential than the 6-port. The 4-port loses torque in the high revs because the stock ignition is weak past 6,000 RPM. The charging efficiency on the 6-port is so low that the ignition is plenty for it.
				__________________ 1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) |
|  11-19-2010, 06:25 PM | #3 |
| Rotary Fanatic Join Date: Apr 2008 Location: Louisville, KY
				Rep Power: 18  |
			Get some TWM IDA style throttle bodies You will get a better power band with a 4 port motor too.
				__________________ My car blows up everytime I start it, it's rotary    |
|  11-19-2010, 06:51 PM | #4 |
				Rep Power: 0  |
			do not have a 4-port motor. custom intake? let's talk design?
|  11-23-2010, 10:18 PM | #5 |
				Rep Power: 18  |
			There are several writeups on intake design. I think that VEX's is probably the best for illustrations. Vex's Intake manifold thread (building new) Older Intake Manifold Thread (modifying stock) Ideation Vex's Build Thread Thanks for the pointer Vex (I knew I had seen the graphics somewhere).
				__________________ 1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) Last edited by NoDOHC; 11-24-2010 at 02:20 PM. |
|  11-24-2010, 12:45 PM | #6 |
| RCC Loves Me Not You Join Date: Jul 2008 Location: Influx.
				Rep Power: 20  |
			may i suggest my build thread for cfd design iterations
				__________________ The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group |
|  11-24-2010, 03:37 PM | #7 | |
| Sigh..... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 20  | Quote:
				__________________ 1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present." | |
|  11-29-2010, 11:34 PM | #8 |
				Rep Power: 18  |
			Unfortunately, my experience appears to indicate that higher compression rotors do not help the power. Still, 338 WHp is awesome (probably on a Dynojet, which would make it approximately equivalent to Defined Autoworks' 430WHp 20B).
|  11-30-2010, 04:42 PM | #9 |
				Rep Power: 0  |
			what about using a complete REW intake (w/ 1" adaptor plate)? half-bridge on the sec ports only?
|  11-30-2010, 11:41 PM | #10 |
				Rep Power: 18  |
			REW intake does not support 6PI for one thing. For another, I don't think the ports would line up well (never tried it with a 6-port, but I doubt that the ports are in the same location between an REW and a 6-port). The stock LIM is fixable, it is the UIM that is hopeless. A custom UIM is not impossible, You could use parts from the stock UIM. It takes skill to TIG cast aluminum together and make it look decent, but it can be done. I was going to do that some day, but I seem to find enough to do.
|  12-01-2010, 10:42 AM | #11 |
				Rep Power: 0  |
			the spacer is there to help with mounting and with the flow.  as far as the REW mani supporting the 6pi, aux will be left open with a insert to ad in flow. fair ?, is the REW intake good in any way for N/A performance?
|  12-01-2010, 01:51 PM | #12 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			I have a question I will interject here.   Has anyone used ditched the turbo's on an REW, and just run it NA? I would be interested to see what it would do, either with stock rotors, or high compression rotors. I am going to build another FC soon, and am going back to NA. Only every other car can be boosted
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  12-01-2010, 04:08 PM | #13 | |
|  12-01-2010, 11:30 PM | #14 | ||
				Rep Power: 18  | Quote:
 I knew a guy who put down 202 WHp on a dynojet using an RE intake. I think that GtoRX7's FC has an NA 13BRE in it at 230 WHp. I would expect that 215-225 WHp is reasonable to expect NA. Quote:
 I have heard of converting a 6-port to a 4-port by removing all the material between the ports, the sleeve, etc. I think this port would be way too big to make power at any reasonable speed or with the intake runner size that even an RE manifold has. I am thinking that a custom intake (for the 6-port) with short runners or ITBs is your friend.
				__________________ 1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) | ||
|  12-03-2010, 11:10 AM | #15 |
				Rep Power: 0  |
			for ITB's,  would 4 38mm throttle be big enough? for a SP or even a half-bridge?
