| Carburetors and Carb Tuning.. All info about old school carb set ups.. |
Delorto 49 Ida?
So I have been slowly installing my delorto these past few days and I'm moderately confused on what to do with a few things...
I have the fuel return line? And nowhere to install it The vacum advance for distributer And i'm not sure what to do with the third cable running along with the choke and accelerator cable Any info would be greatly appreciated |
48ida
Waffles - hmmm good
Its a 48 DHLA (sidedraft).
If you don't have a return regulator then just cap the return for now. I run the vent line into the middle iron nipple and have a PCV valve attached to the oil filler nipple with vacuum on that. Don't run vacuum advance since I improved my ignition. Was that third cable for cruise control? Not sure what you want to do with that.
The only thing I can come up with is a hot start motor assist or a ac component
what's the esiest way to update the vaccume advance |
KTEC
Make sure your mounting it the correct way. If you mount a side draft in a down draft position, it will not work. And vica versa...
i mounted it the way i removed it off of my parts car im just a little confused about what is a must to keep for correct operation and which of the cluster of cables and lines i can chuunk
Waffles - hmmm good
If you throw some pics up we might be able to help better.
#9 |
Well that didn't work haven't been using the forum long enough to figure out how to import pics T_T
#10 |
KTEC
Use photo bucket or something similar. It's usually easier that way than to load pics directly to the forum...
#11 |
![]() DOES ANYONE ON HERE KNOW WHAT FILTER SIZE WILL FIT THIS RACING BEAT INTAKE COVER?? DELLORTO DHLA 48IDA IM HAVING NO LUCK T-T Last edited by Mateepay; 11-12-2010 at 10:02 PM. |
#12 |
![]() this is the piece idk what to do with do i need this to run the carb?? |
