			 Too many questions!
				Rep Power: 0 ![]()  |
			I have built my Streetported N/A engine(S4). I re-used the harness and have been on a stock ECU since the rebuild.
			When I finally upgrade to Rtek, I will make a new harness. ECU and Main harness. I would like to keep it a stock harness with integrated safety features(more than just fuses). What can I do to the engine harness to accomplish this goal? How should I have the PDA wired to be "apart" of the system? What could be the best option to reduce the added resistance? Keep these in mind: Still have emissions Its a S4 N/A Cold start blocked E=IxR The 7 experiences all the seasons I'm not ready for a full stand-alone ECU 75% daily driver/25% track car I kept the topic open so we can help others with a similar dilemma. Thank you for viewing.
	1987 Mazda RX-7 GXL I'm starting to understand...  |
			 The fan hit the shit!
				Rep Power: 16 ![]()  |
			What all are you trying to gain by doing this? Just to make a new harness to cure shotty 20yr old wiring or to eliminate unnecessary wiring and fuse's?
	Zack.  |
		#3 | |
			 Good stuff at low prices
			I didn't quite understand what you meant by including the pda into your harness. I know that on the rtek there is a seperate db9 cable that comes off the side of the ecu for a serial cable to a pda connects.
	If your just wanting to clean up your harness i would strongly suggest just sticking with a oem mazda harness and ,maybe depinning the wires you don't need nor use, but as you said you are still running emissions. So pretty much there isn't going to be many unused wiring. As far as reducing resistance, as long as there is any ghetto hack job wiring done, you should be alright. Just be sure theres no crusty green or blue corroision on any of the wiring also. Zack.  |
		#5 | ||
			 Too many questions!
 I will be re-making the OEM harness(fully copying the original), but the "problem circuits" will have there(their?) own grounds instead of connecting it to a ground ring terminal. Also, I will try to incorporate a circuit breaker on the battery power wire and, 2 cut off switches. One switch to shut off power to the alternator; the other will stop power to the fuel pump.
			Gotcha, as for your interior harness, what all do you plan on keeping? Your really asking for a lot, a lot of work. It would be easier to just get a painless harness for the interior if that's the route you intend on going with.
	For the engine i can understand what your trying to do and again it will be a lot of painstaking work, not to mention trying to hunt down the individual pis for each of the factory connectors. But if you decide to make it a good word of advice is that the proper crimp and contact will almost always be better than a solder joint in terms of reliability and performance. Zack.  |
			 Too many questions!
			It reads as a lot of work, but it isn't. I'm basically copying the old one, but guaranteeing room for error. The connectors can be purchased new because Honda and some Mitsubishi vehicles use the same connectors. Better yet, the wires can be had with the exact same color identification as stock(blue/yellow and stuff) from a electronics store.
			Painless harness's, to me, are for dirt track racers and dune buggies. I'd rather have an ARC 8000 harness for the interior instead; I'm still going to use the stock harness. The interior doesn't need much modification other than a relay for the power windows, which is easy. I'm relocating the idiot light board to the dash. The engine harness is going to get a lot more attention than the interior. The way I decide on soldering vs. crimping a connection is: If its going to stay the same for a while, solder. If its going to be changed from time to time, crimp. I know what you mean though.
			 Too many questions!
			If I change my mind on stock connectors, I'll get these...
			http://www.diyautotune.com/catalog/7...kit-p-380.html
		#9 |
			Depending on how long you can wait, we will be offering replacement engine harnesses for the S4 at some point. All brand new stuff. You will be able to order it without certain connectors as well since most people do not use the emissions equipment anyways. It will be similar to the factory harness but different enough to be a bit more durable and as always use higher quality components where possible.
		#10 | |
		#11 | ||
			 Too many questions!
		#12 |
				Rep Power: 19 ![]()  |
			Weatherpack plugs are overkill for the interior.
	Weatherpacks are designed for exterior use to prevent water and moisture from entering the connection. This is the reason why they have rubber plugs in them. Almost every connector in your engine bay is like this. Hell, I guess it doesn't hurt to do this for the interior, but I think it's a waste of time and money. Are you trying to build an electrical harness that'll outlast the chassis and your life? ![]() Personally, I prefer Deustch stuff. The plugs are a lot more lower profile than the Weatherpack crap. You have the option of using machined pins (more expensive) or stamped and rolled pins (on a budget). Only caveat is that the crimper can be big bucks for the machined pins. There is nothing wrong with a crimped connection. A crimped connection can be just as good, and sometimes better, than a soldered connection. Soldered connections have a disadvantage in the automotive environment as they can fail due to vibration and moisture - this is where a properly crimped connection is superior. -Ted  |
		#13 | |
 I agree the weatherpack is a bit much for an interior. That's kinda a waste of money. For cheapness sake you could just use 093 molex connectors from radio shack to do the same thing for 1/3 the price. And they are a lot more compact. Widely available as well.
		#14 |
				Rep Power: 18 ![]()  |
			Ted is right about the crimps vs. Solder. The Solder makes a good connection - electrically, but the wires get bent a lot more on the edges of the solder and it is much more likely to fail - mechanically. The OEMs all run a single wire from point A to point B. Where I have seen a splice in an OEM harness, it has been crimped and sealed. There is a reason that they do it this way and it isn't cost. Sealing is critical to avoid corrosion on crimp connectors.
	1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic)  |
