Old 11-08-2010, 08:42 AM   #1
13bboy
13bboy is on a distinguished road
microtech two step?
im considering applying a basic two step set up with my microtech lt10s, im not 100% sure how much to retard the timing (bit of a noob). just looking for peoples opinions. Thanks
13bboy is offline   Reply With Quote
Old 11-08-2010, 11:47 AM   #2
sen2two
KTEC
sen2two's Avatar
I have spoken to a few people who have used built in 2-steps, not many people have been happy with it.
Your much better off using MSD 2 step. It's cheap and proven. And there's zero chance of you messing something up. It does all the hard work for you. The only thing you do is choose an RPM...
what I have:
What I had:
Old 11-08-2010, 07:07 PM   #3
13bboy
what else is needed besides the MSD two step module?
Old 11-08-2010, 09:05 PM   #4
If you're still running the stock ignition system, you'll need THREE of them.
One for each channel:
1) both leadings
2) Trailing, front
3) Trailing, rear
Old 11-08-2010, 09:11 PM   #5
13bboy
im running a microtech ecu with an x4 ignighter and bosch coils
Old 11-08-2010, 11:53 PM   #6
In that case, you need FOUR of them - one for each coil.
Old 11-09-2010, 01:36 AM   #7
13bboy
thats what i figured, thanks for that
Old 11-09-2010, 09:19 AM   #8
sen2two
KTEC
sen2two's Avatar
I am running the stock ignition but... You would only really need two of them for the leading. One for each coil. Then have 2 solenoids shut the trailing off completely when the 2-step is engaged. One solenoid for each coil.
I am only running one MSD 6al, and one 2-step module. With the solenoids shutting off the trailing when activated. This is how most people do it.
what I have:
What I had:
Old 11-09-2010, 07:57 PM   #9
13bboy
thats a good idea, thanks sen2two
