^thanks for the heads up Ted, from what I had read so far I thought I could use just the gears and didn't need any other modifications other than extending the e-shaft jet grooves.
This is why I created the thread, in case I miss something. I'll be sure to reread the info I had found before doing anything. If there is any doubt I'll keep the stat gears I already have. I'm not building a high rev, high output engine so I really don't need the hardened stat gears. One question, are the Cosmo 13B-RE gears a direct swap? I'm still researching that one, but had been told they are hardened but a direct swap...but they also do NOT have the better bearings that the FD and RX-8 have. Just to complete the conversation for anyone who is searching for related info. I had read conflicting info about using RX8 gears. Some said they are a direct swap and other said you need to shave off like .001 on 13B e-shaft to accommodate the gear. |
