Need help diagnosing problem (video)
I was driving to cincy when my car started losing power. I had no throttle response, could barely make it up hills, and the car would sputter under heavy throttle. No check engine light came on and none flashed would I grounded the connector. I've checked the following:
TPS (in range) AFM (all values in spec) Fuel Pressure (stayed around 35-40psi) Spark on all plugs I checked for vacuum leaks and found none I even created a gasket "block off plate" for the acv to make sure it wasnt leaking Now when i give it any gas or WOT i can't get it to go above 2000rpms. I've attached a video for helping diagnose this. Cost me $500 to tow back home so I'm pissed and ready to blow it up. The only thought I have now is either throttle body or clogged cat. Honestly I have no idea though. Thanks for the help. |
Rep Power: 20 ![]() |
I feel your pain brother, I'm dealing with the same BS on my car and want to blow mine up as well (anyone have a Barrett M107 available?!) You have checked all the things I would have recommend to. OMP? Is there a possibility that the AFM is bad and still checks out well with a meter? I have an extra AFM I just need to see if it is a S5. Did you check the TPS with a DVOM or did you just use the two light method? If not, do it with a DVOM and check for smooth movement across the throttle range.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
Rep Power: 22 ![]() |
Have you checked for fuel yet? I know you put in a new pump, but what about the filter?
My $200 offer stands!
Senior Member/Lounge Rat
FUEL.FILTER!!
Replace.it..My.old.S5.had.the.same.problem. |
Rotary since 1972
Rep Power: 17 ![]() |
Sounds and acts like a blocked exhaust.
.drives like MrMagoo!
It's an S5..you are in LIMP MODE Dude!
that is what happens when your OMP is either on it's way out or Disconnected. Check the CODES,,pull em up and see. |
^ ^ ^ "No check engine light came on and none flashed would I grounded the connector."
Seriously! Get a new fuel filter! Haha
It's cheap and may fix the problem. |
#9 |
Does the check engine light come on ever? I was working on somebody's car once and was thrown off because it wasn't throwing a code.. then I realized the light never came on. Pulled the piece out of the dash and found out the previous owner had pulled out the bulb.
2004 RX8 GT 1986 RX7 Track Car: 13B Bridge Port w/ Renesis Internals and Weber Carb 2003 MazdaSpeed Protege 1988 RX7 Convertible - new project 2004 Impreza and 2003 Legacy wagons for hauling groceries and The Dog |
#10 |
Well that is definitely a problem, he may very well have the same issue.
#11 |
the light works, fuel filter was changed not long ago....
#12 |
Well, assuming it's not in limp mode then, my next thought would be a clogged cat.
#13 |
Was the strainer changed also?
#14 |
yep.
#15 |
Actually, the clogged cat is a distinct possibility.
I hate to say it, but check compression. How is your oil pressure? It could also be a bad connection in the wiring harness.
