Old 09-02-2010, 10:23 AM   #1
Dusted RX
Dusted RX is on a distinguished road
Tire touched fender
I've been running Eibach SP/Illumina's for several years. My 99 spec chin spoiler hits the ground on the outside trailing edge, both sides, during hard sharp turns. This spring I put on 17 x 8 +35 wheels on the front. Yesterday I hit a smooth deep bump with a bit of wheel turn and pulled the fender out a little bit, taking a very thin, narrow chunk of tire off. I am 25.0 in. from the ground to the top of the fender wheel well. I probably need an other half inch of clearance to prevent this from happening again.
Should I:
- get new springs that don't lower the front end as much? Any recommendations on specific springs that are similar or even slightly higher spring rate?
- can a spacer be added to the spring seat to raise the car slightly?
- Buy some Tein Flex coilovers?
Thanks for your thoughts.
Mark
Dusted RX is offline   Reply With Quote
