#18 |
Compression Tester Man
Rep Power: 17 ![]() |
Here's the sheet showing the AFRs getting very close to 14:1. Tuner shut it down at that point and we went to Plan B, which was, as I said earlier, to replace the Rtek-chipped ECU with a stock unit and using the S-AFCII for tuning.
If you have not had your car on a dyno, or using some other way, to verify safe AFRs, I would recommend that you do that before pushing the revs. |
