08-16-2010, 10:15 PM | #1 |
Clean S4 Nutswinger
Where to place jackstands without rear subframe?
Just like the title says, I began jacking up the rear of my FC, preparing to drop the rear subframe, when I discovered I didn't know where to put the jackstands once the subframe is gone. The only place I can see is those 'rails' that run along the underside, I've always avoided using those for anything since I've seen them crushed so bad.
Immediate help would be appreciated, the car is up in the air supported by the floor jack right now .
-Ted -1986 Mazda RX7 Sport [DD/beater]: engine finally let go at 205k. parts car status. -1986 Mazda RX7 base [resto-mod project]: S5 n/a swap in progress. |
08-17-2010, 12:11 AM | #3 |
Big Ugly
Never mind! I agree above.
Boosted Big Body On 335's PS3 ID: Rotordad 1986 Mazda RX7 GXL - Street ported 13BT, Haltech, 62mm, ect. 2006 MazdaSpeed 6 - Eagle, Wiseco, Cobb, ect. Last edited by RotorDad; 08-17-2010 at 12:20 AM.. |
08-17-2010, 01:49 AM | #4 |
You could also use a "snowshoe" method and place a load displacing object (whatever you want to use such as a piece of wood) between the jackstand and the body but as close to the pinch weld as possible. That's if you're worried about destroying the said area.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
08-17-2010, 06:55 AM | #5 |
don't touch the pinch welds, especially if there is any type of surface rust ANYWHERE.
I use the "frame" rails underneathe the muffler heat shields. If you're dropping the subframe, the exhaust is gone so it's 3 10mm bolts and the heat shields are gone exposing a VERY stong jack point.
08-17-2010, 05:20 PM | #7 | |
Clean S4 Nutswinger
08-18-2010, 10:50 PM | #8 |
The rear tow hooks are another good spot
08-19-2010, 12:04 AM | #9 |
That's what I always use, right on the two bolts.
