Old 07-26-2010, 01:29 PM   #1
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
the BAC and idle
am i understanding this correctly.
when accessories are switched on (headlights, etc), the BAC kicks in to help hold idle.
also....
my car tries to idle at something like 250 and below (im serious) and partially maintains it too... its weird really. is the idle adjustment screw the only way to adjust the idle? the idle seems to be the only thing really keeping me from enjoying and actually driving/trusting the car.
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 07-26-2010, 03:03 PM   #2
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
I think S4 BAC valves have an adjustment screw. You need to check/set your TPS sensor via multimeter or test light methods. <~ needs to be done every time you adjust your idle screw or bac.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 07-26-2010, 04:10 PM   #3
My5ABaby
My5ABaby's Avatar
I'm not sure which accessories, but yes, it's to bump up idle under load.
Community Service Manual
RotorWiki
Old 07-26-2010, 07:32 PM   #4
Silver86
now what?
Silver86's Avatar
man... i need a 2nd set of hands... cant get this thing to idle for shit.
aka - 20bforme
Old 07-27-2010, 02:53 AM   #5
a 250 idle is pretty indicative of one rotor operation. Check the usual culprits, injectors, ignition. The hit the FSM and follow the procedure for adjusting the idle. The n/a does not have the adjustment screw on the BAC, those are the turbo cars.
The BAC is to maintain idle. You want, at least the way I set them inthe aftermkt ecu world, a solid idle without using the BAC valve, use thee BAC valve to maintain it.
Old 07-27-2010, 08:45 AM   #6
Silver86
now what?
Silver86's Avatar
hmm... wouldnt surprise me if it were running on 1 rotor...wouldnt also surprise me if i lost a rotor since i last checked. i should just bite the pillow already and buy the 20b. also found out, theres a small air pump under the BAC (cant remember what it was called), well that was unplugged and the hose plugged.
aka - 20bforme
Old 07-27-2010, 09:32 AM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
Can you read 250 RPM on these cars (assuming you are looking at the stock tachometer)? I thought the first line was 500 RPM (so it goes 0, 500, 1000, 1500, etc...).
Any trouble codes? My idle has gotten loopy lately after driving all weekend and I got Code 17 (O2 Sensor Feedback System).
Old 07-27-2010, 10:22 AM   #8
Silver86
now what?
Silver86's Avatar
250 was just a guess... usually sits somewhere between the 1st and 2nd lines on the tach... engine shakes like a mofo under 1k (underlying problems i already know about).
no trouble codes... that i know of... never thought of trying to pull a code.
aka - 20bforme
Old 07-27-2010, 11:52 AM   #9
Your car is almost 25 years old.
Do a tune up first.
The idle is the last thing you should be worried about.
Old 07-27-2010, 12:04 PM   #10
Silver86
now what?
Silver86's Avatar
Do a tune up first.
LOL... now why didnt i think of that... i get so caught up in what im trying to figure out that the simple things evade me.
aka - 20bforme
