Old 07-20-2010, 07:35 PM   #1
Rotary91
Rotary91's Avatar
Rotary91 is on a distinguished road
This has been asked, I have read about it but would like to make sure.
Will an s4 OMP work fine with an s5 FC?
'91 FC3s
Rotary91 is offline   Reply With Quote
Old 07-20-2010, 08:00 PM   #2
NO.
Old 07-20-2010, 10:04 PM   #3
Rotary91
Rotary91's Avatar
thank you
'91 FC3s
Old 07-20-2010, 11:35 PM   #4
Nismo
400WHP or bust
Nismo's Avatar
NO.
To build on this; so you might gain a little more knowledge, the S4 is mechanically operated with a shaft from the Throttle Body to the OMP, the S5 is electrically controlled by the ECU.
Originally Posted by Rotary91 View Post
thank you
You are welcome.
Old 07-21-2010, 12:56 AM   #5
FC Zach
FC Zach's Avatar
And to further complicate things, , , You could, but you would have to use an earlier OMP with the appropriate front cover and a re-chipped S5 ECU (to avoid limp-mode).
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 07-21-2010, 09:15 AM   #6
Rotary91
Rotary91's Avatar
Thank you Nismo and I don't think I want to modify this engine just for an OMP, it has 231K miles and is about to die.
'91 FC3s
Old 07-29-2010, 10:17 PM   #7
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
What makes you say its about to die? My buddy's has 240k miles on it and still pulls just and strong as mine. If your worried about not getting enough oil injected into your motor just premix.
