Rotary since 1972
Rep Power: 17 ![]() |
Depending on the whiteness you could be fine. As long as your exhaust temps are OK and you are not over heating I wouldn't be too concerned.
You can richen it with the mixture control. Located just aft of the air filter box. It is a recessed screw in a brown case. There were two curved arrows also showing an L and R. It does not take much to make a drastic change. If you really have to do it in slot sized increments. In lieu of that you could add a little Redline Two stroke race oil also. That would richen it up. |
