Rep Power: 20 ![]() |
Help me choose an ECU
Damnit TTT if you say buy a Motec I'm going to stab you in the eye and lick it like a lollipop. I'm a very poor newly wedded college student.
Okay, here's the deal. I'm interested in buying a stand alone ECU for my car. Here's what I currently have and what I want:
I'm considering one of the three following ecu's: Sprint RE Platinum Sport 1000 Platinum Sport 2000 Which one do I go for?
Rep Power: 10 ![]() |
Buy a MoTeC M600
/Thread
Or if you think the 26B is in the realm of possibilities, get the M820
Now /thread
I hate you. So much.
![]() Hey Phil/ZGN could you make a smiley that shows a smiley stabbing another smiley in the eye, removing the eye, and then licking it? K-thnx bai! TTT you have three choices! Sprint, 1000, 2000. I'm aiming to spend maybe around 2k MAX for the entire setup.
From what I understand the Spirit RE is specific to 2-rotor engines so cancel that.
What's the difference between the 1&2000? Make a list of the I/O's you need for the 26B and get the ecu that meets the requirements. The software is the same yes? Lacking?
#6 | |
As for the IO's, that's the problem I'm having trouble with. I can't remember where I put the Excel Spreadsheet I had of everything, so I'm back to trying to figure it all out again. From what I can remember there's a few necessary things needed to run the engine. Feel free to correct the list if it's wrong. input/output list 1. ignition x 4 (o) 2. Fuel x 4 (o) 3. Map (i) 4. Coolant Temp (i) 5. Fuel Pump (o) 6. Radiator Fan (o) 7. AIT (i) 8. E6PI (o) -- this is something special 9. O2 (i) 10. EGT x 2 (i) Am I missing anything?
So I found a few things that may be helpful in deciding.
The PS2k lists the following:
7 Analogue Voltage Inputs 1 Digital Switched Input 3 Digital Pulsed Input Though I know we don't need Cam position and I don't readily have access to road speed (I assume at each wheel, or do them mean the read out from the tranny?), do I need barometric pressure? They list the following for output
Some questions I have though: Does the PS2K include built in controller, or if I already have a controller will it still be able to use the auto-tune feature?
Start with this
![]() http://www.motec.com/filedownload.ph...pdf?docid=1214 Things to add to your list would be Required Inputs 1) Crank Position 2) TPS 3) MAP 4) AIT 5) Coolant Temp 6) Lambda Things I would have 7) Oil Temp 8) Oil Pressure 9) EMAP 10) EGT Front Rotor 11) EGT Rear Rotor 12) Fuel Pressure 13) Low Sump 14) Low Coolant 15) Wheel Speed x4 if you want to do traction control OR just pull a speed signal off the tranny. Speedometer Solutions makes a Hall Effect thread-in sender. Outputs - Injector x4 Ignition x4 Fuel Pump relay (Also used for coils and injectors and solenoids) Thermo Fan Tach Driver BAC WG
#9 | |
#10 |
If you really want to log everything and keep an eye on it without running two senders for everything, you need a digital dash of some sorts and CAN communication. And yes, they kick ass.
#11 | |
I'm working through the spreadsheet now and I'll post up the results. Quick question: Can Digital Pulse Inputs (DPI) be used as a Digital Switch Input (DSI)?
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 05-23-2010 at 10:33 AM. |
#12 |
Sprint RE is out, doesn't have enough inputs for me to make it a viable option with a digital dash. The PS1k is still in the running though--I'm waiting on the answer to the DPI and DSI question though.
#13 |
Never mind. Answered my own question after going through the manual they have hidden on the site.
#14 |
Alright, another question for the general community: How does the Digital Dash hook up to the ECU? I'm assuming via the CAN bus system, but after going through both the dash manual and the ecu manual I don't see any instructions on installation to the ECU.
#15 |
Here's the link to the spreadsheet I've done. It's still quite rough, but adjustments might be needed here and there.
http://spreadsheets.google.com/ccc?k...LMHIxcHc&hl=en
