OBEY YOUR MAZDA
Racing Nikki issue
Hey Guys
I have a racing Nikki on a streetported 12A. Well the thing is, as soon as the engine is running it feels like the throttle has to overcome a very strong vacuum, I really need to press the pedal hard to overcome the "binding" Any inputs are appreciated. Kim ![]()
There is a part of the linkage that looks like a rod with a spring on it. This is supposed to rest on a pivoting "hook", but is often left loose and allowed to drop down. This is referred to as the "teeter totter". If you conduct a search, you should find info on it. This is you most likely suspect.
You can also do some more research over at www.sterlingmetalworks.com , where there is a wealth of information on Nikki carbs. Good luck. ![]() .
OBEY YOUR MAZDA
Only sprung rod on this carb is for the acc.pump
The problem is only when the engine runs, when it's shut off - no problem. Primaries and secondaries open together.
If I'm not mistaken you should be using the black spacer between the manifold and carb.
Either you are psychic, or there are photos that I cannot see.
#6 | |
Rep Power: 22 ![]() |
You can't see the pics??
OBEY YOUR MAZDA
Hmm - thanks guys.
How could I forget about the spacer
Let us know if that works out for you.
#9 |
OBEY YOUR MAZDA
I will check it in the week to come, racecar is at my friends place. Thanks
#10 |
Yeah,the filtering at, um, the place I'm at right now, won't let the pictures through if they are hosted. If the pics are uploaded to the site, then I'm fine.
