Old 04-29-2010, 04:06 PM   #1
Garfinkles Motor Works
Remove the omp and block the hole
For the cars using premix and needing to remove the oil metering pump I have made a 3/16 steel plate to cover the oil hole . The steel is thick enough to hold the gasket and not flex. The plate is very slightly larger than the metering pump so the area around the bolt holes is stronger .The gasket material is rubberized and the bolts and washers are stainless steel .The price is $18 plus shipping .If you need one they will be available through this forum only and as with all my products and work you will be satisfied with thefit and function.
