running but alil slugish and back fireing?????
Ok I finally got it to stay running and everything I have been posting a lot on here lately I changed the spark plugs and now it runs but really slugish and popping and all what else could it be
Rep Power: 22 ![]() |
Wicked vacuum leak, blown engine, timing WAYY off, bad gas....
Alot of variables.
Well I know the motors not bad less than two thousand miles on it and would a blow off valve not hooked up right cause a big vac leak and the gas could be to and the guy i got it from mixed way to much oil with the gas as well.
Senior Member/Lounge Rat
A BOV could cause a vac leak, but I don't know if it'd cause the car to run sluggish and backfire.
Was the motor broken in done properly? |
Yeah im pretty sure it was what are the requirements
Aight I just asked the guy he told me pretty much everything that was in the thread
And the compression is 115 front and back
#9 |
Hm.
#10 |
I'm starting to think its the afm or bad coil or wires cause when you touch where the boot meets the wire it shocks the piss out of ya
#11 |
Rep Power: 20 ![]() |
Did you put the right wires on the right plugs?
#12 |
IS L1 AND T1 the front rotor and L2 T2 the rear
#13 |
Ok I unplugged the pressure sensor and it runs just fine but when I plugged it back in runs like crappy
#14 |
Ok got a ajustable fpr what should I put the pressure at
#15 |
Search much? Throwing any codes? TPS adjusted properly?
