Old 03-16-2010, 09:20 AM   #1
kenn_chan
kenn_chan is on a distinguished road
life of rotors with race pads
Ok,
current setup:
1st gen body
2nd gen crossmember swap
929 master adapted to FC3s mastervac
tilton bias adjuster
front:
315mm x 28mm front rotors
nissan Z32 front 4 pots
hawk 9012 blue race pads
rear
FC stock rotors
FC calipers
hawk Black race pads
front rotors are chewed pretty badly after 80 laps at ebisu west. from two different weekends
anybody with experience with the blues? do they normally tend to chew rotors this bad? the rears with the hawk blacks are still OK for a couple of more track events.
not that I mind, ya gotta pay to play but if I can find pads that hold up to the heat like these blues do without chewing hell out of the rotors I would have more money to spend on other things (more time at track) or possibly condoms to stop the spread of my dna
kenn
kenn_chan is offline   Reply With Quote
Old 03-16-2010, 04:02 PM   #2
Kentetsu
Kentetsu's Avatar
My info probably won't help you much, but using Hawk pads (I forget which type, but are recommended for autocross) along with the cheapest rotors found at Rockauto (think $15.00 range) I haven't had any issues at all. 1 1/2 years on that setup and both pads and rotors are still in great shape. Probably about 15,000 miles on them.
Old 03-16-2010, 04:10 PM   #3
josh18_2k
from what i've heard blues eat rotors when theyre cold and/or wet. so driving them on the street will kill your rotors, but if you swap them at the track (minimizes cold contact), the rotors will last a long time.
Old 03-16-2010, 05:53 PM   #4
moremazda
shookmotorsports.com
moremazda is on a distinguished road
You may not be getting the rotors hot enough for the the blues. Have you a reason for running the Blues over the HP+?
Ryan
moremazda is offline   Reply With Quote
