Old 02-28-2010, 02:47 PM   #1
rotaryguy481
rotaryguy481 is on a distinguished road
Default Electric Fan
What kind of electric fan works good on a FC n/a
rotaryguy481 is offline   Reply With Quote
Old 02-28-2010, 04:46 PM   #2
Default
All different kinds. Shook Racing makes a sweet set up with an aluminum shroud. Spal makes great fans. Stay away from the auto parts cheapies.
Alot of FC guys will use a Ford Taurus or Escort e-fan. They fit the radiator great, and draw a small amount of amps.
Old 02-28-2010, 04:59 PM   #3
rotaryguy481
Default
sweet thanks alot bro didn't know what to do lol
Old 02-28-2010, 05:00 PM   #4
My5ABaby
My5ABaby's Avatar
Default
http://www.aaroncake.net/rx-7/efaninstall.htm
Community Service Manual
RotorWiki
Old 02-28-2010, 07:01 PM   #5
88turboii
destroy, rebuild, repeat
88turboii's Avatar
Default
i run the single-speed taurus fan, havent had any problems with it
Old 02-28-2010, 07:21 PM   #6
Dazed and Rotarded
douche bag
Dazed and Rotarded's Avatar
Dazed and Rotarded is on a distinguished road
Default
You can use a dual from a audi with alittle trim.. The taurus work's great also like mentioned.
- chris
xbox live - GraveConditions
R.I.P paul gray - # 2
Dazed and Rotarded is offline   Reply With Quote
Old 03-01-2010, 02:32 AM   #7
Default
The best fan for an N/A RX7 is the one that the factory fitted on there. I see toooooooo many efans installed incorrectly and they do more harm than good.
Old 03-01-2010, 03:35 AM   #8
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
Default
True but an efan helps clean up the engine bay, and used properly works as good if not better then stock.. Just stray away from cheepies either use a good fitting stock one off another car of spend the money for a good low amp efan
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 03-01-2010, 11:54 AM   #9
infernosg
IT'S ALIVE!
infernosg's Avatar
Default
Try to find a good (high flow rate, low amp draw) 15-16" puller, pick up a SPAL (or other) programmable thermoswitch and custom make a fan shroud out of aluminum, fiberglass, etc. to fit to fit over your radiator. That should be the makings of a good e-fan setup...
Old 03-01-2010, 03:05 PM   #10
Polito Racing
so you got pistons oh wow
Polito Racing's Avatar
Polito Racing is on a distinguished road
Default
Im running the later model mercury cougar fans setup in my car and works great. its a double fan setup and the shroud fitted prefectly on my radiator. It looks very clean.
Polito Racing
2000 F-350 SD (Daily Driver)
2002 CBR 954RR (Back on the Road)
1987 RX-7 Turbo II(red bullet!!)
Polito Racing is offline   Reply With Quote
Old 03-03-2010, 11:19 PM   #11
knonfs
knonfs is on a distinguished road
Default
Flex a lite black magic fan, used for over decade back home (90F avg temps), and never had a problem.
knonfs is offline   Reply With Quote
Ad Management by RedTyger
