Rep Power: 21 ![]() |
Headunit in an FB
its been like...years since i have done this. Is there anything weird involving the install? I swear there is.
if i remember correctly when i had mine installed i seem to remember something about the installers having an issue with the actual mounting of the HU in the dash. could be wrong tho its been like 5 years
yea the original unit isnt too wide. im more concerned with wiring but i dont think there is anything
ZOMG WTF BBQ!!!
There's no wiring harness for the FB. you have to run your own wires unless you feel like cutting up your stock harness and splicing.
im fine with splicing. i wasnt sure if there was weirdness with a factory pre amp
Non Member
As far as I know, the factory amp has to be bypassed. The best way to do it, is run new wires to the speakers. Especially since you're likely going to replace the stock speakers anyhow.... I believe the stock speakers use a plugin that is not compatible with aftermarket replacements.
Crutchfield offers (last I knew) a dash kit for the 84/85 models, but you're on your own for 79-83. I have no clue if they offer any kind of wiring kit to use the stock wiring. I actually found the radio plug adapter for my old nissan truck hanging on a peg at an autozone, but I had to hunt for the 2 into 1 coaxial plug...... |
ZOMG WTF BBQ!!!
Just bypass the amp. That's what i did. Those old wires were rotting away anyways.
Most of the 1st Gens require the dash to be cut if it has the original P chassis or corporate unit in the dash. Some of the later years like 84-85 will allow you to slightly trim the radio hole and mount a standard Din sleeve.
Due to the age of the car and possibility that it maybe factor amplified it is generally best to go ahead and run new wires for speakers. I thinks some of the very early models used common ground speakers which will not work with today’s modern headunits. Here is what I have in my notes on the 1st Gen radio stuff, hopefully it will help answer some questions. 1979-83 Mazda RX7 Car Audio Wiring Guide Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Red/Black Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Blue/White Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4″ depth 2.3” Car Audio Front Speakers Location: Kick Panels Left Front Speaker Positive Wire (+): Blue/Red Left Front Speaker Negative Wire (-): Blue/Yellow Right Front Speaker Positive Wire (+): Blue Right Front Speaker Negative Wire (-): Blue/White Car Audio Rear Speakers Size: 6 1/2″ depth 3” Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Blue/Red Left Rear Speaker Negative Wire (-): Blue/Green Right Rear Speaker Positive Wire (+): Blue/White Right Rear Speaker Negative Wire (-): Blue/Green Metra Kit’s available for easier installation: 98-7599 Pocket Kit 99-7500 Multi Dash Kit 99-7501 Multi Dash Kit 70-1781 Wire Harness 71-1781 Wire Harness Auto Side That what it should be. However if someone’s changed stuff it may nolonger be correct. Hope that helps you out some. If you need further info don’t hesitate to ask.
Anthony Bulger SportTuner.com
#9 |
ZOMG WTF BBQ!!!
Who carries the dash kit for a 85' GSL SE? I'm cleaning up my interior and i need to take my ghetto rigged one out...
#10 |
Generally the dash kit was for a shaft mount conversion.
#11 |
i just got the stock clarion working
#12 |
ummm you dont need to cut anything guys..... all the chips are there more or less, I have a aftermarket deck running the stock wiring, the wiring harness kit works fine, more kits come with a blue clip for the rear speaker. the reason you dont see a blue clip in the dash is because its under the rear bins, all I did was unplug the blue chip from the stock amps and make a extension cable for the chip under the rear bins. its really easy to do. all u need is a male and a female stock 4 pin clip like what you find in the 1st gens and 2nd gens and put them on a long peace of wire. boom done and no cutting needed. I'll post some pics tomorrow when I'm up at my car
