Old 01-31-2010, 01:27 PM   #1
rotaryguy481
rotaryguy481 is on a distinguished road
runs a couple of times
i have a 87 seven N/A and i can get it to run a couple of times and when i turn it off it will not start for a couple of hours then when i try it it starts just fine for a couple of times then the prossess starts all over again can anyone give me an idea where to start
rotaryguy481 is offline   Reply With Quote
Old 01-31-2010, 01:33 PM   #2
as in starts and runs until you turn it off next? Is it drivable will it runs? Does this only occur while the car is fully warmed up?
Old 01-31-2010, 01:33 PM   #3
You have leaky fuel injectors. Pull them out, get them serviced by someone reputable.
Old 01-31-2010, 02:14 PM   #4
rotaryguy481
it does it when its run for alil then it does it and yes it runs and drives a couple of times then does the no start thing
Old 01-31-2010, 03:31 PM   #5
Two major possibilities, one has already been said by Titanium TT (TTT); Leaky fuel injector. The other possibility would be low compression (especially if it's an NA). As such check compression to ensure proper compression
Old 01-31-2010, 05:32 PM   #6
rotaryguy481
well the compression is around 112 on front and back is that ok
Old 01-31-2010, 06:32 PM   #7
Yes, that's really good. It's your injectors. I would put money on it UNLESS when it's not starting it's becuase the prior time you drove it it wasn't fully warmed up. If it was taken to normal temp before shut down than it's your injectors leaking.
Old 01-31-2010, 06:53 PM   #8
rotaryguy481
how much could i get a good set for and which ones are the primary and which are the secondary
Old 01-31-2010, 07:21 PM   #9
primary are tuck under the intake manifold with the ports actually on the engine, secondaries are found on top of the intake manifold and are considerably easer to access
Old 01-31-2010, 08:55 PM   #10
$400 for a new set or ~$100 to get them serviced.......................................... ........................................
Old 01-31-2010, 10:11 PM   #11
rotaryguy481
aight thanx guys now i just got to find a place around me to service them lol
