#16 |
On used plates you need to lap first to get the step wear down flat, on new plates they do a good job from the factory making them flat and true( never checked but will from now on). Re-nitrate to a low heat to have it harden down about 3-4 thou deep after lapping. That low heat 99% will not warp the plate and no need for a touch up on re lapping after nitrating. All the plate are dial cheeked for warpage and if necessary the will be re lapped very lightly.5 thou at most... But never had a warped plate yet coming out of the nitrating process...
But at the same time i will start checking the new plate from Mazda for warpage.. you never know... At the same time everybody has there own take on lapping or lapping with nitrating. But i can guaranty you that lapping a used plate 2-3 thou deep and checking the hardness with a dial indicator. it a much softer material with out the nitrating. Thus making sense that wear will occur more rapidly in a plate with out nitrating than with... Hope that helps... |
#17 |
Hot damn this sounds like a good deal
#18 | |
New Mazda plate from the factory no miles on it. RC 38-39 Used plate after lapping /Grinding 2-3 thow deep. RC 21-23 Used plate after lapping/grinding with re-nitride. RC 40 Hope that this helps... |
#19 |
Wow! That is a significant change.
I may have a set for you to resurface in a few months when I tear the engine in my car down to install the new 9.5:1 rotors. I didn't know about this and lapped the irons myself (although I didn't remove any 0.002-0.003", more like 0.0005"). I am sure they will need it again by then if the hardness is that much different(with 10,000 miles on the clock). I should have known that there was some reason that everyone didn't just do the lapping themselves.... I will let you know if they show appreciable wear (I don't want this engine to fail anytime soon).
1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) Last edited by NoDOHC; 09-29-2009 at 07:18 PM. |
#21 |
Thats a good deal!
#22 |
At the dirt track.
Hi could you tell me what the RMS (Surface finish)is after the final lapping?
Thanks.
Rollin like a reuleaux. Unstoppable. |
#23 |
Just finished up a set of plates for a customer 3 rotor...
Enjoy ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The cost for me to have these done went up, so i'm pasing the savings on. 480.00 for a 13b 640.00 for a 20b Last edited by To_Slow; 01-07-2010 at 05:07 PM. |
#24 |
At the dirt track.
#27 | |
Reconditioned plates... REMAN
#28 |
Rep Power: 10 ![]() |
That's some nice, thorough work there. Whats the turn-around time for the service?
#29 | |
crash auto?fix auto
I know we did a huge number of fasteners/pipes/studs etc. up here last year and by the time we gathered crap between my builder myself and few other guys the price to plate the items was almost halved due to the volume. But yeah I imagine the dipstick tube/rear iron coolant tube are a biatch to remove
#30 |
Rotary Masochist
Sure about that number? We had some plates ground a while back and took some measurements of re-ground used and brand new OE plates. We found a new set of OE plate to be about 12 Ra (micro-inches) on average. Our guy got the used plates to an average of 8 Ra. The rough correlation between the RMS and Ra is around 11%. So our measurements for the stock plate would roughly be 13 RMS. They look to good to be as bad as your measurement would suggest.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
