|  11-16-2009, 05:51 PM | #1 |
| Run DAMN YOU!!! Join Date: Nov 2009 Location: Las Vegas, Nevada
				Rep Power: 0  |  Huge Idiling and Stutter Issue!
			OK so I own an '84 GSL-SE. I have a huge problem with cold starts. When I start the car it likes to shoot a bellowing white cloud out of my exhaust continuously until the car warms up and then no problem. I'm guessing i have some kind of coolant seal issue because there is no more white smoke once the engine is up to temperature. The seal is much better then. I would like to know a reason for this and a possible fix for my problem. Also while driving the car once i get to or past 3k rpm it likes to stutter. Lets say if I were to be driving in second get completely off of the clutch and floor it, Nothing happens.  I have no idea what is wrong with it at this point. everything up until around 3k is fine but not there after. The car has 150,000 miles. Aftermarket intake and RB headers and no air pump if that can give any kind of problems. Thanks in advance.
				__________________ www.VegasRotary.com - Vegas' local rotary car community! |
|  11-16-2009, 07:29 PM | #2 |
| Respecognize! Join Date: Jul 2008 Location: Δx = ħ/2Δp
				Rep Power: 21  |
			what are the plugs looking like? i would believe the coolant seal issue to be correct.
				__________________ For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook |
|  11-16-2009, 08:22 PM | #3 |
				Rep Power: 0  |
			Brand new plugs. Replaced them last night. Old ones were done from all the cranking.  Do you have any idea what would cause it to have no power past 3k rpm. I have a feeling it just might not be getting fuel because it stutters at 3k and past that is nothing.
|  11-16-2009, 08:31 PM | #4 |
				Rep Power: 21  |
			how long have you owned the car, did it sit for any length of time?
|  11-16-2009, 09:00 PM | #5 |
				Rep Power: 0  |
			Its sat for like 2 years.
|  11-16-2009, 09:03 PM | #6 |
| Rotary Fanatic Join Date: Feb 2008 Location: Denver, NC
				Rep Power: 18  |
			First thing you need to do is get a good manual and replace all of the vaccum lines with new ones so you know that they are in good shape. Do one at a time so they don't get mixed up. Then you need to start troubleshooting the FI system. There are alot of things that help or hurt the idle control. A good write up I found a while ago is this one.I think I saved it from the other forum. Hope that doesn't cause any issues. http://fm.no-ip.com/gslseidle.html |
|  11-16-2009, 09:45 PM | #7 | |
				Rep Power: 0  | Quote:
				__________________ www.VegasRotary.com - Vegas' local rotary car community! | |
|  11-17-2009, 08:02 PM | #8 |
				Rep Power: 21  |
			well if the car sat for an extended time i would check the fuel system. might not be able to get enough fuel from something being clogged. Check the filter first, operation of the injectors second.
|  11-18-2009, 03:35 PM | #9 | |
 Gonna drop the tank, clean it out and get some good stuff in there. Checked timing and not sure which dot on the pulley needs to be lined up for tdc. Both of the dots have no color anymore.
|  11-19-2009, 05:35 PM | #10 |
| Rotary since 1972 Join Date: Nov 2008 Location: Tucson
				Rep Power: 17  |
			White smoke is water. Do the engine seal check. Start with cap off radiator, if it bubbles afraid you have a seal gone.
|  12-13-2009, 09:00 PM | #11 |
| The Newbie Join Date: Apr 2009 Location: Flat Rock
				Rep Power: 0  |
			white smoke is not always water .. smell it, taste it, love it!!
|  12-17-2009, 02:07 PM | #12 |
| The Newbie Join Date: Oct 2008 Location: Phoenix, AZ
				Rep Power: 0  |
			Did you check compression? Sounds like if it's not the fuel, it might be running on one rotor. Take the top two plugs out, one at a time, and turn it over by hand and see if you get 3 strong puffs of air from each rotor.
				__________________ '85 RX-7 GSL-SE Current Driver '85 RX-7 GS Current project '84 RX-7 Parts car-SOLD '91 RX-7 VERT SOLD |
|  01-07-2010, 01:26 PM | #13 |
				Rep Power: 0  |
			I checked compression and the puffs are very consistent and strong on each rotor.
