Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > JKL Racing Engineering
JKL Racing Engineering shop.jklre.com (CA) Custom RX body/performance parts, JDM importer
Old 03-25-2008, 01:11 AM   #1
mdude
mdude is on a distinguished road
Here are the SMB Products we will be offering for the FD:
HEADER PIPE
The header pipe has a pressed shaped section out of the turbo to allow the exhaust gases to flow and expand into the chamber to minimize the restriction we found that by then sending the gas through a 3½" pipe that noticeable gains were evident, the header pipe then is gradually tapered down at the cat end to 3" diameter to suit the same bolt pattern as the original exhaust. all from 304 stainless steel.
Part Number: MRHP353
HI FLOW CAT CONVERTER
Ceramic core high flow converter, the lead in and lead out tubes and flanges are 304 stainless steel, we have found the ceramic core high flow converters are satisfactory for up to around the 200kw mark over that consider the metallic substrate converters.
Part Number: MRHCC
METALLIC SUBSTRATE CONVERTER
Metallic substrate converters give an exceptionally high flow rate for their size compared to traditional ceramic core converters, for example the back pressure in the header pipe with a conventional hi flow cat fitted is around 4psi with a metallic substrate it is around 1.5psi
Part Number: MRMSC3
METALLIC SUBSTRATE CONVERTER WITH MUFFLER
This is a variation on our very successful Metallic substrate converter 3" as shown above.The addition of an 8" x 5" oval muffler is for those who may already have another brand of "cannon type" type muffler fitted. And wish to, or need to make the exhaust system quieter.Or for some one who simply want to make their existing system quieter. The muffler is a straight through 3" designed for maximum flow.
Part Number: MRMSC3M
DUAL TIP 3" CAT-BACK EXHAUST
The lead in tube, and the center tube of the muffler is 3" diameter stainless steel CNC mandrel bent to ensure accuracy of fit, the hanger brackets are to suit the original mountings, the body of the muffler is 304 stainless steel, around the center core is stainless steel wool in blanket form, with hi temperature hi density acoustic fibre packing, the the body of the muffler is basically the same shape as original, shorter in length, to allow for smoother flowing bends into the muffler. The tips are twin wall stainless to stop heat discoloration.
Part Number: MROTRM3
4" SINGLE EXIT DOLPHIN TAIL CAT-BACK EXHAUST
The lead in tube, and the center tube of the muffler is 3" diameter stainless steel (ALSO AVAILABLE IN 3½") CNC mandrel bent to ensure accuracy of fit, the hanger brackets are to suit the original mountings, the body of the muffler is 304 stainless steel, around the center core is stainless steel wool in blanket form, with hi temperature hi density acoustic fibre packing, the the body of the muffler is basically the same shape as original, shorter in length, to allow for smoother flowing bends into the muffler. This exhaust is constructed in the same way as the Dual Tip muffler with the exception that it has a 4" bent exhaust tip as per the original 12 hour cars.
Part Number: MR4RM3
TITANIUM TIP CAT-BACK EXHAUST
The lead in tube and the center tube of the muffler is 3" diameter stainless steel CNC mandrel bent to ensure accuracy of fit, the hanger brackets are to suit the original mountings , the body of the muffler is 304 stainless steel, around the center core is stainless steel wool in blanket form, with hi temperature hi density acoustic fibre packing, the titanium tip is added polished and colored to bring out the brilliant colors of titanium.
Part Number: MRTRM3
mdude is offline   Reply With Quote
Old 03-25-2008, 01:29 AM   #2
mdude
Here are the products that we will be offering for the RX8:
The system SMB has developed for the RX8 is a High flow cat section plus a cat back system.
A metallic substrate cat converter is used in the cat section to allow for even greater flow than the original. Our testing result proved that in this section the optimum pipe dia is 2 3/4" (which is a unique tube dia in stainless available to SMB)
The cat back section comprises of an intermediate tube, plus a rear muffler section, the cat back section utilizes a mixture of tube dia to achieve the desired results.
SMB has achieved a system that gives good increases in rear wheel Kilowatts, a noticeable driving difference through the increase in torque and quicker throttle response. The exhaust note is typical of SMB, i.e. a subtle exhaust note on constant throttle (so no cabin drone) but opens up under load to give you that true sports experience, through the design we managed to minimize the pop back under de-acceleration to an absolute minimum, the heat retained by the rear mufflers is kept to a minimum by the use of SMB's unique packaging material. (so no more smelling melting rear bumpers)
Through out the development process the staff at SMB deliberately did not view any other brands or products for the RX8. Which gave the system we produced a visually unique system, through the placement and angles the mufflers are positioned at.
This system is one of the best designs we have produced.
Here is a video/sound clip of the full exhaust system:
CAT BACK EXHAUST SYSTEM
SMB has achieved a system that gives good increases in rear wheel Kilowatts, a noticeable driving difference through the increase in torque and quicker throttle response. The exhaust note is typical of SMB, i.e. a subtle exhaust note on constant throttle (so no cabin drone) but opens up under load to give you that true sports experience, through the design SMB managed to minimize the pop back under de-acceleration to an absolute minimum, the heat retained by the rear mufflers is kept to a minimum by the use of SMB's unique packaging material. (so no more smelling melting rear bumpers)
Part Number: CBMR8
METALLIC CONVERTER
A metallic substrate cat converter is used in the cat section to allow for even greater flow than the original. SMB's testing result proved that in this section the optimum pipe dia is 2 3/4" (which is a unique tube dia in stainless available to SMB)
Part Number: MR8HCC
METALLIC CONVERTER FOR FORCED INDUCTION CARS
For this application we use a 5" 200 cell high flow cat with a larger diameter resonator, the pipe work is to suit 3" tube.
Part Number: MR8HCC3
CATLESS MID PIPE FOR FULL RACE APPLICATIONS TO SUIT NORMALLY ASPIRATED VEHICLES
Part Number: MR8CLMP
CATLESS MID PIPE FOR FULL RACE APPLICATIONS TO SUIT FORCED INDUCTION VEHICLES
Part Number: MR8CLMP3
Old 03-25-2008, 03:08 AM   #3
mdude
We know that these prices might be alittle higher then previous group buys for SMB Products. Previous sales for SMB products in North America were priced accordingly in order to introduce SMB's Product Line and hopefully obtain feedback from customers. Also contributing to the increase in SMB prices is continuing decline of the US Dollar.
NOW ON TO THE PRICES. PLEASE NOTE THAT THESE PRICES WILL NOT INCLUDE SHIPPING. SHIPPING WILL BE DETERMINED LATER.
FD: If you are using paypal:
  1. FULL SYSTEM (3” with metallic cat converter) - FSMRM3 - $1,556.97
  2. FULL SYSTEM (with hi flow cat converter) - FSMRH - $1,454.81
  3. FULL SYSTEM (3” with metallic cat converter w/muffler) - FSMRM3M - $1,649.76
  4. HEADER PIPE (variations) - MRHP353 - $638.15
  5. HI FLOW CAT CONVERTER - MRHCC - $367.56
  6. METALLIC SUBSTRATE CONVERTER 3” - MRMSC3 - $468.96
  7. METALLIC SUBSTRATE CONVERTER WITH MUFFLER 3” - MRMSC3M - $590.88
  8. TI TIP CAT-BACK EXHAUST 3” - MRTRM3 - $537.51
  9. 4” DOLPHIN-TAIL CAT BACK EXHAUST 3” - MR4RM3 - $569.13
  10. TWIN TIP REAR MUFFLER 3” - MROTRM3 - $630.53
RX8:
  1. CAT BACK EXHAUST SYSTEM - CBMR8 - $995.83
  2. CAT BACK EXHAUST SYSTEM (For 3" version for forced induction cars) - CBMR83 - $1,045.39
  3. METALLIC CONVERTER - MR8HCC - $514.63
  4. METALLIC CONVERTER (FOR FORCED INDUCTION CARS) - MR8HCC3 - $537.51
  5. CATLESS MID PIPE (FOR FULL RACE APPLICATIONS) - MR8CLMP - $147.98
  6. CATLESS MID PIPE (FOR FORCE INDUCTION VEHICLES) - MR8CLMP3 - $224.22
FD: If you are using echeck:
  1. FULL SYSTEM (3” with metallic cat converter) - FSMRM3 - $1,515.16
  2. FULL SYSTEM (with hi flow cat converter) - FSMRH - $1,416.07
  3. FULL SYSTEM (3” with metallic cat converter w/muffler) - FSMRM3M - 1605.16
  4. HEADER PIPE (variations) - MRHP353 - $623.96
  5. HI FLOW CAT CONVERTER - MRHCC - $361.51
  6. METALLIC SUBSTRATE CONVERTER 3” - MRMSC3 - $459.86
  7. METALLIC SUBSTRATE CONVERTER WITH MUFFLER 3” - MRMSC3M - $578.11
  8. TI TIP CAT-BACK EXHAUST 3” - MRTRM3 - $526.35
  9. 4” DOLPHIN-TAIL CAT BACK EXHAUST 3” - MR4RM3 - $557.02
  10. TWIN TIP REAR MUFFLER 3” - MROTRM3 - $616.57
RX8:
  1. CAT BACK EXHAUST SYSTEM - CBMR8 - $970.89
  2. CAT BACK EXHAUST SYSTEM (For 3" version for forced induction cars) - CBMR83 - $1,018.96
  3. METALLIC CONVERTER - MR8HCC - $504.16
  4. METALLIC CONVERTER (FOR FORCED INDUCTION CARS) - MR8HCC3 - $526.35
  5. CATLESS MID PIPE (FOR FULL RACE APPLICATIONS) - MR8CLMP - $148.53
  6. CATLESS MID PIPE (FOR FORCE INDUCTION VEHICLES) - MR8CLMP3 - $222.48
We also offer discounted pricing for 3.5" & 4" exhaust systems, metallic cats, and header pipes. Please pm us for pricing.
Once the Group Buy is over and the order is placed, it will take approximately 4-5 weeks for the products to reach our docks.
Please send payment to sales@jklre.com. Include your forum name, real name, and which part numbers you are purchasing.
If you have any other questions, Please feel free to pm me or Kevin. Thank you.
Old 03-28-2008, 11:49 AM   #4
mdude
up.
Old 03-31-2008, 09:08 PM   #5
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
I just noticed that you guys still left RCC in your introductory title description on the evil forum. They haven't jumped your case with that yet? I actually posted in there thinking I was in RCC even though the layouts are completely different colors
Guess I'll ask my question again here as well. Can this also include their universal things such as their oval resonators?
EJayCe996 is offline   Reply With Quote
Old 03-31-2008, 09:42 PM   #6
mdude
http://smb.net.au/index.htm
go on the smb website and find the exact part you are looking for. You can jsut pm me the part number so i can get you a price.
Old 04-02-2008, 10:35 PM   #7
mdude
We are also offering any part from the Mazda SP car. These parts are carbon fiber and are quite expensive.
http://smb.net.au/mazdarx7zone.htm
Old 04-02-2008, 10:35 PM   #8
mdude
We are also offering any part from the Mazda SP car. These parts are carbon fiber.
